drivers seat bottom
Old Jun 9, 2015 | 08:53 AM
mjf07922's Avatar
mjf07922
2nd Gear
Default drivers seat bottom
I just picked up a 1998 in great condition other than the fact the driver's
seat lacks cushioning in the bottom (base). I don't want to replace the whole seat as the leather is in great shape. I saw I can pick up a replacement foam base. Anyone ever changed one of these out?
Any idea how involved a job?
Old Jun 9, 2015 | 09:25 AM
runner140*'s Avatar
runner140*
Purchase new seat foam from one of the Forum vendors. I did this a couple of week-ends ago. Turned out great. I used the YouTube video.....it took, start to finish, about an hour.
Old Jun 9, 2015 | 09:26 AM
peteinpa's Avatar
peteinpa
Did the same this past weekend. Worth the effort IMHO.
Old Jun 9, 2015 | 09:51 AM
bjones7131's Avatar
bjones7131
Not hard at all, I removed my seat, bottom leather cover and foam and put in felt over the springs. My foam seemed to be in pretty good shape so I kept it. Disconnect electrical connections, remove 4 bolts and remove the seat. Cover is held in place by 4 hog rings and when I replaced it i used zip ties instead of hog rings. Raise seat up as high as it will go before starting and when all 4 hold down bolts are off, get a 2x4 block of wood to lift and scotch up seat to make access to electrical connections easier.
Old Jun 9, 2015 | 10:52 AM
zachaeous's Avatar
zachaeous
Default seat bottom foam
I also replaced the bottom seat foam on my 2001. It was not a hard job at all. I also added the c5 seat rebuild kits form southern car parts. It strengthens the stock foam and raised the seat height just a little till they get a little use but I feel it made a great difference even with the new foam. The rebuild kits also came with great directions for the entire job. Good luck with your upgrades.
Old Jun 9, 2015 | 12:12 PM
Jason913's Avatar
Jason913
You guys convinced me to order this foam kit and shim repair from southerncarparts. I am unhappy with the driver's seat cushion sag, with only 33k miles! The seat rock is starting to develop too. Hopefully it's night and day after $75 in parts and 2-3 hours of time
Old Jun 9, 2015 | 12:17 PM
2FAS4UU's Avatar
2FAS4UU
I will throw in a small suggestion in regards to the installation of new foam. Try to find a upholstery shop or fabric supply house and purchase about 1 sq. yd.x 1" of a good dense foam and while you have your seat apart, remove the back seat cover off. Make a paper template (optional) of your side bolsters, cut the 1" foam, apply it to the bolsters with a can of 3M spray glue and trim any foam square edges to a rounded shape. Cover back of seat with a piece of plastic sheeting (optional) like a dry cleaner bag and re-assemble. By simply adding the 1" foam to bolsters you will find it far more supportive and comfortable while in the seat. Takes hardly any time to do this seat mod and makes a real difference in feeling more snug in your seat. Jus Say'n !! This also can be done to the bottoms to customize fitment. If you were in my locale I would lend you a hand.
DanSavage's Avatar
DanSavage
Yes, you can pay the Corvette tax and buy ready-made seat repair kits for $40 each.
Or, you can go down to your local home improvement store and spend $15 for a door mat that's large enough to do both seat bottoms and $7.50 for 20 feet of clear vinyl tubing. When I did my seats, I chose to buy some hog ring pliers ($19 for economy set) rather than using nylon tie wraps because the nylon tie wraps will eventually decay and break whereas the steel hog rings will last for the life of the seats.
I used the Junkman's step by step instructions. (See: DIY - Replacing the Leather on the C5 Sport Seat)
Old Jun 9, 2015 | 12:36 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
http://www.corvetteflorida.com/forum...d.php?t=102575
A diy i did replacing the seat bottom foam.
Old Jun 9, 2015 | 01:27 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Djmotorsports makes a stronger foam seat bottom if you want something firm. I put on in my z06 and it was a great upgrade compared to the stock cushion.
To drivers seat bottom
