I thank your car is awsome where did you get fender flares with duct / scoop in front also
front bumper
My rear quarters are the L5 2" wide rear quarters with fully functional factory C6 Z06 brake scoops worked into them. The front bumper fascia is an oem C5 bumper with the scoop from a C6 Z06 front bumper worked into it and the front C5 fill plate shaved. Did the front bumper my self. Working with a manufacturer to start reproducing them.
I saw a part of the bumper build, kudos for the impressive work. With you teaming up with a manufacturer, will you guys be making a front bumper that just has the filler plate smoothed over or will it be a duplicate of yours, to include the lower intake vent you cleverly used two fog/screen vents put together? I wouldn't mind a smooth bumper with the lower vent, but that upper one requires an aftermarket hood seeing as the sides flow right into the added bump from yours.
