New first time vette owner
Old Jun 17, 2015 | 12:58 PM
jglassmaker's Avatar
jglassmaker
Default New first time vette owner
Hey all, finally got a C5Z! I've wanted one of these since I starting driving cars and I finally got one!!
I've been all over the forums the last week absorbing all this knowledge you guys have all collected and shared, thank you all!
I have a few TLC projects to do on my new (used) vette and one was lowering it from what appears to be stock height. I found guides and everything - I just haven't found a few bits of info yet and was hoping I could clear some of it up and finally say hi....
1.) "Lowering on Stock bold" - are there aftermarket ones? I can't find anything..
2.) "removed lowering bolts" - simply remove the bolt to get max stock lowering?
3.) Any kind of formula like x threads = 1" lower on stock setup?
Old Jun 17, 2015 | 01:32 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
And congrats!
Old Jun 17, 2015 | 01:59 PM
jglassmaker
Originally Posted by corvettezman
And congrats!
Thanks! I posted a crappy photo until I get some good ones.
Old Jun 17, 2015 | 02:23 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Congrats and nice car....You can remove the front bolts to get the max lowering there. The back bolts you can't remove. They do make longer bolts for the back and that should get you scrapping the grass. The fronts you can get after market as well but they are basically the same thing you have now except the rubber spacer is cut off. I don't have a formula I used but a trial and error kind of thing. Adjust a little here and there until you're happy with it and then get an alignment done. You go to low though and your ride comfort will suffer. But that's just me as I didn't care for the ride quality when lowered to much. So I raised mine back up a bit. Good luck.
Old Jun 17, 2015 | 02:26 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Congrats on a nice looking Z!
Plenty of threads on lowering a C5. Yes, there are lowering kits (bolts) from various suppliers, but you really need to get coil overs if you are going that route as your shocks will bottom out too quickly otherwise = evil handling on the street.
I lowered mine on stock bolts, not quite all the way...and cut 1/3 of the bushings on the rear. Very happy with ride and handling and looks better that stock ride height IMO (see pic).
Welcome to the asylum!
Old Jun 17, 2015 | 02:40 PM
corvettezman
There is no such thing as a crappy photo of a C5. Looks great!
Old Jun 17, 2015 | 02:45 PM
jglassmaker
Thanks for the info guys!
I will be posting again in a few days with another issue but need to gather up all my info yet. MS4 cam initial idle on start is very bad but I'm still checking common things like vacuum leaks
Old Jun 17, 2015 | 03:35 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Congrats on the new ride! Enjoy!!!
Old Jun 17, 2015 | 03:37 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Welcome to the C5 madness, congrats on the new ride. Looks great!
Old Jun 17, 2015 | 03:45 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
wow,, nice looking hot rod Z... Most of the time the low/rough ideal can be cleaned
up by spraying/cleaning you TB & same to your MAF. You can get spray cleaners for them at any local parts store, or wallyworld..
Good luck with your new ride..
mike
Old Jun 17, 2015 | 04:27 PM
jglassmaker
Thanks everyone! This is a very friendly and still active community
I came from being a long time Camaro owner and this is already a better experience and more active place
Old Jun 17, 2015 | 04:52 PM
corvettezman
Just don't stray into the "off Topic " section.
Old Jun 17, 2015 | 08:55 PM
Congrats on getting a great looking car. How about some more info on the car - miles, year, any mods, etc.?
Old Jun 17, 2015 | 08:59 PM
jglassmaker
2004 C5Z 16k miles
Long tubes, no cats
Magic stick 4 cam kit & tune
Forgot the shifter
C6 Black rims
Old Jun 17, 2015 | 09:05 PM
IMXCITD's Avatar
IMXCITD
congrats and enjoy!
Old Jun 17, 2015 | 09:13 PM
myredhead1's Avatar
myredhead1
Congrats on the car and some great mods!
Old Jun 17, 2015 | 09:37 PM
Not4spd's Avatar
Not4spd
Congrats on the purchase and welcome to the family. Are the rear wheels smaller than the front or am I being decived by the rear wheel wells.
Now get rid of those body side moldings. I'm a tad partial to yellow:
To New first time vette owner
Old Jun 17, 2015 | 09:48 PM
rx4arx's Avatar
rx4arx
Nice looking car. Nice start to the hobby!!
Old Jun 17, 2015 | 10:28 PM
jglassmaker
275 in the front and 295 in the rear - so just a bad image.
That is a nice yellow vette you have there! I think I will remove the side molding!
Old Jun 17, 2015 | 10:37 PM
Not4spd's Avatar
Not4spd
Thanks I was on the fence, but glad I pulled them off. Gives the car a much smoother look IMO.
