Installed new battery and ...
Old Jun 23, 2015 | 11:00 AM
Hammer99's Avatar
Hammer99
Default Installed new battery and ...
Now the Check Engine light is on. It wasn't before.
Does anyone know how to correct?
Old Jun 23, 2015 | 11:14 AM
dadaroo's Avatar
dadaroo
Old Jun 23, 2015 | 11:28 AM
Hammer99's Avatar
Hammer99
Originally Posted by dadaroo
Gotcha. Thanks!
Old Jun 23, 2015 | 11:30 AM
Macleod52's Avatar
Macleod52
Copied and pasted from your other thread as it looks like you double-posted.
Did you pull your codes? You should be able to clear codes and the light will go off if it's just a fluke. If there's something wrong the code/light will just come back.
Did you make sure the new battery was fully charged (should read 12.7-12.9v)? If not clear your codes and fully charge the battery and see if that fixes your issue. If your battery is too low it can throw all sorts of codes.
Old Jun 23, 2015 | 11:49 AM
JR-01's Avatar
JR-01
First thing to do. If battery is 100%, you cleared codes and it's still on, disconnect, wait 20 seconds and reconnect.
Old Jun 23, 2015 | 03:39 PM
Hammer99's Avatar
Hammer99
All set... thanks. Light is out.
New battery shows 14.1V on DIC
To Installed new battery and ...
