Wheel weight adhesive
Old Jun 25, 2015 | 03:15 PM
Glasact's Avatar
Glasact
Default Wheel weight adhesive
I recently purchased a 2003 coupe with the polished wheels. The previous owner had new michelin tires installed, and the installer removed the wheel weights inside the barrel of the wheel , but left the foam adheasive strips. What product should I use to remove the adhesive? Is there a clear coat on the wheels? I was thinking of using laquer thinner but not sure if that would harm my wheels.
Old Jun 25, 2015 | 03:19 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
laquer thinner will affect the clear coat I would use brake dry clean or goo be gone !!!!!!
Old Jun 25, 2015 | 03:20 PM
JEH03Vette's Avatar
JEH03Vette
I would try some Goof Off and maybe a little heat from a heat gun or a hair dryer to loosen the gummy stuff. Good luck.
Old Jun 25, 2015 | 03:38 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Lighter fluid or tire buffer cleaner is what i use at my shop. Doesn't affect the clear coat.
Old Jun 25, 2015 | 03:59 PM
jallen355's Avatar
jallen355
Wd40
Old Jun 25, 2015 | 05:24 PM
CQRT's Avatar
CQRT
Originally Posted by jallen355
Wd40
Worked well for me . . .
Old Jun 25, 2015 | 06:08 PM
73Corvette's Avatar
73Corvette
All good suggestions above...
Old Jun 25, 2015 | 06:13 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Wd40
Old Jun 25, 2015 | 07:29 PM
allred's Avatar
allred
Simple Green also works, and is safe.
Goo-Be-Gone or Goofoff if the adhesive is thick or stubborn.
Old Jun 26, 2015 | 08:19 AM
WD40 or Goof Off will do the trick.
Old Jun 26, 2015 | 09:15 AM
Glasact's Avatar
Glasact
Thanks for all of the suggestions. I will be using them this weekend.
To Wheel weight adhesive
