[Z06] ? about headlights
Old Jun 30, 2015 | 07:26 PM
cwmoss's Avatar
cwmoss
Default ? about headlights
just need to know if high beams and low should both come on when high beams are used
Old Jun 30, 2015 | 09:17 PM
63Corvette's Avatar
63Corvette
No, not allowed by US law.
Old Jun 30, 2015 | 09:56 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Only when the high beams are on and you pull back on the turn signal stock.
Old Jul 1, 2015 | 05:44 AM
Street Approved's Avatar
Street Approved
Now they do sell a wire that bypasses that to where both comes on.
Old Jul 1, 2015 | 08:12 AM
cwmoss's Avatar
cwmoss
and just where do you get that,inquiring minds need to know
Old Jul 1, 2015 | 09:12 AM
philadd's Avatar
philadd
I don't believe that's true. A lot of cars had low beams that stayed on with the high beams. As an example, on my '99 Honda Accord both sets of lights would be lit.
One of our forum vendors... I believe it's the Hi-4 relay kit, sold by Radioflyer, but I might be wrong.
Old Jul 1, 2015 | 10:07 AM
cwmoss's Avatar
cwmoss
I do thank you much
Old Jul 2, 2015 | 11:08 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
close but not quite, but I have yet to see this and it would make bi-xenon headlight illegal.
The regulation is that no more than 4 forward projecting lights may be illuminated at any time. For a typical reflector-type headlight system, it makes sense to shut off the low beams when high beams are active since high beams are designed to illuminate further and in order to be effective foreground lighting needs to be minimized. The problem is with the C5's horribly dated fresnel headlights and older halogen bulbs, the driver needs all the output he can get just to see safely.
Old Jul 10, 2015 | 09:52 PM
cwmoss's Avatar
cwmoss
You are correct radioflyer is the vender very nice setup but have a problem and have emailed him here and the web site and no response to any emails
Old Jul 11, 2015 | 07:30 AM
TheRadioFlyer
Supporting Vendor
True, but for the C5 corvette (and most other GM vehicles around that era with 4-bulb headlights), the high beams would shut off.
Interesting, I have not seen anything yet. Try going direct to my email: radioflyer97@gmail.com
To ? about headlights
