temperature dash bulb went out
Old Jul 6, 2015 | 03:02 PM
fastbydrmike's Avatar
fastbydrmike
Default temperature dash bulb went out
Hi you knowledgeable folks! Has anyone changed the bulb behind the temperature glass on the C5? Mine was getting dim and I went to get a bulb and it finally went out. I am asking how to get that part of the dash apart. I think I need to open the arm rest and remove the TC switch which allows me 2 screws to remove that piece but I am not sure. I did a search and no luck.
Mike
Old Jul 7, 2015 | 04:10 AM
Choreo's Avatar
Choreo
Are you referring to the TEMP Display on the A/C Control unit? If so, and it is getting dim, it is most likely the cold-soldered joints needing re-soldering - there is no "bulb" to replace. I had to re-solder mine a few years ago and it is still working.
There are instructions here on the forum explaining the procedure.
Old Jul 7, 2015 | 06:43 AM
fastbydrmike
That is exactly what I am talking about. The dealer sold me a bulb but I can jus as easy resolder the part.
Old Jul 7, 2015 | 09:17 AM
dadaroo's Avatar
dadaroo
Here is a link that tells you how to access it and fix it. There are 2 versions of the circuit board for their location but each uses 8 of these surface mounted resistors. Use as little heat input as you can or they will "move" around. Best to have someone help hold them in place with something.
https://www.corvetteforum.com/forums...splay-fix.html
If you have a manual shifter you do not have to remove the shift ****. If you lift the console surround up and separate the boot from it, it will rotate/tilt and you can lift the console up and off. This will leave the boot and shifter in place.
Mr. Sam
PS: The buttons do use bulbs so if you have any out you can use Radio Shack 272-1092 bulbs to replace.
Old Jul 7, 2015 | 11:04 AM
jdsaengine's Avatar
jdsaengine
Mine almost totally went out. If you tap hard on the display with your finger and it gets bright for a moment, then more than likely its the loose resistor problem. I've been tapping on mine for couple of years before finally doing the solder fix about a month ago. There is a sticky on the method.
It actually only takes about 15 min to get the circuit board out and on a bench. Use a low wattage solder wand (got mine at Lowes) not a big gun.
Definitely have a second person hold down each resistor with a pencil or tooth pick as you solder. Those little suckers (about 1/2 the size as the end of a pencil) will move around in a heart beat !!
First time I did not use flux paste and the solder did not flow well enough to make a good connection. So I had to redo it about a week later. put a little flux paste on a tooth pick and apply to each end of each resistor. Solder flows much better, then clean up the excess with a little alcohol and Q-tip. Mine has been bright as new for last month.
Old Jul 8, 2015 | 09:30 AM
fastbydrmike
You guys are the best! I know what I am doing this weekend.
Thanks,
Mike
To temperature dash bulb went out
