Removable roof squeak
Old Jul 7, 2015 | 08:16 PM
Daleford's Avatar
Daleford
Default Removable roof squeak
Is this a common problem? If my 01 coupe goes through a dip in the road or hits a bit of a rut, above my head there is an annoying squeak. [am I spelling squeak correctly?]
What is good to spray on the contact areas for this problem?
Old Jul 7, 2015 | 08:21 PM
01silvercoupe's Avatar
01silvercoupe
Make sure the latch bolts are tight before you try lube. If they are tight maybe a little silicon lube spray would do the trick.
Old Jul 7, 2015 | 09:25 PM
Fcar 98's Avatar
Fcar 98
Remove the roof, on top of the windshield were the latch attaches there are little rollers in there that should be free to roll. I had to free mine with lubricant. I would recommend not to tighten the latch, especially if it is lexan. I believe that undo pressure can create stress on the roof.
Old Jul 7, 2015 | 09:45 PM
Daleford's Avatar
Daleford
Thanks for the tips. I should mention that my noise could almost be described as a "snap" sometimes.
Old Jul 7, 2015 | 10:30 PM
If it is a snap, you may need to adjust the fit of the top to the car. Here are some files that might help you out. You could also try some dielectric grease to the weatherstripping to see if that helps.
File Type: doc
File Type: doc
File Type: doc
To Removable roof squeak
