Help with front lights.
https://www.corvetteforum.com/forums...l-in-here.html
You might need these as well.
The parts needed for this are included in the above mentioned kit. It is only necessary for the driver's side.
And as Lee mentioned we have no idea where you are located. NO info in posts or profile.....
And your inside knowledge can be extrapolated to many other places, so be careful.If you are not mechanically inclined, or don't have time to do it, then you have to expect to spend some money... just be aware of your options and their costs.
Dealership quoted you "about" $750 for both sides and the open recall. They will replace your motors with new ones with plastic gears, as the originals. It's true you will have a warranty on the job done, but your motors "will" fail again because of the plastic gears "after" your warranty had expired
On the other hand, the open recall is just 3 washers to shim the driver's side motor and they are included in the kit I mentioned in my previous post
For comparison, the kit to service both motors in a 97-Early 2000 is just $89.95 and for a Late 2000-2004 is $91.95 and your motors will never fail again because of the plastic gears. You can also order the rubber bump stops and have a basically new mechanism.
This is not as difficult as it may seem and you'll know it was done right (not to mention the satisfaction of doing it yourself)
