Air comb radiator clean
Old Jul 11, 2015 | 08:34 PM
dhfva63's Avatar
dhfva63
Default Air comb radiator clean
I just used this 24" air comb to clean the radiator and condenser. Got out a fair amount of debris as shown. A lot of dirt and grit. Might not do as good a job as pulling the radiator, but it worked pretty well and I'll like having the air comb in the toolbox.
Old Jul 11, 2015 | 08:37 PM
williame3590's Avatar
williame3590
Where'd ya git it?
Bill
Old Jul 11, 2015 | 09:36 PM
dhfva63's Avatar
dhfva63
Amazon. Innovative Products air comb.
Old Jul 11, 2015 | 09:50 PM
williame3590
Thanks.
Bill
Old Jul 11, 2015 | 10:02 PM
JR-01's Avatar
JR-01
http://www.ebay.com/itm/24-Air-Blow-Gun-Aluminum-Easy-To-Handle-NEW-/261556033669?pt=LH_DefaultDomain_0&hash=item3ce5f4588532 bucks is a little steep. $7 for these.^
Save your money and make your own from this. I bought two. One I heated it and bent to 90 degrees then shortened the end. The other I straightened, put a screw in the end and drilled a couple of holes in the side. Works exactly the same as the 32 dollar model..
Old Jul 11, 2015 | 10:55 PM
Choreo's Avatar
Choreo
I just received this one yesterday...
Forney 75336 Air Blow Gun, Lever-Type with 2-Foot Extension and Rubber Tip, 1/4-Inch Female Inlet - Air Tool Fittings - Amazon.com Forney 75336 Air Blow Gun, Lever-Type with 2-Foot Extension and Rubber Tip, 1/4-Inch Female Inlet - Air Tool Fittings - Amazon.com
$17.99
Old Jul 11, 2015 | 10:56 PM
Looks like a good product to have in the toolbox.
Old Jul 11, 2015 | 11:51 PM
olbear1962's Avatar
olbear1962
Old Jul 12, 2015 | 12:04 AM
scarecrowkc5's Avatar
scarecrowkc5
I modded mine to spray (low pressure) water.
I hit it with the air then switch over to water.
It's as clean as I can get it without pulling it out.
To Air comb radiator clean
