M6: Hand resting on shifter
Old Jul 14, 2015 | 01:02 PM
calvins's Avatar
calvins
Oldtimer
Default M6: Hand resting on shifter
There was a threat the other day discussing that it's bad to rest your hand on the shifter when driving. I'll be dang if I can find that sucker, and no, I didn't subscribe....
Anyhow, I couldn't see how that'd hurt anything as long as you weren't pushing/pulling on it.
People were saying their fathers said that was bad - I don't understand. I'm wondering if their fathers said/meant to keep your foot off of the clutch pedal if not shifting.... now that one I understand, but how resting a hand in a shift **** could damage the car escapes me.
Old Jul 14, 2015 | 01:09 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the tread was "a stupid question" and there is none, I have mine on the shifter most of the time !!!!(that's why I have a manual so I can be in the gear I want for as long as I want !!!!!!!!!) I do not load the shifter !!!!
Old Jul 14, 2015 | 01:18 PM
calvins's Avatar
calvins
Oldtimer
Well, that was my line of thinking too. I just wondered of people were really trying to say about the foot on the pedal. That's why the thread.
I've always rested my hand as well.
Old Jul 14, 2015 | 01:48 PM
grantv's Avatar
grantv
Although I don't have it at hand, I am pretty sure my BMW 325i manual states not to rest your hand on the shifter.
And: http://www.streetlegaltv.com/?p=1102450
Also from a quick Internet search:
The reason you should not do this is because the weight of your hand, and arm, is multiplied due to leverage. This can move the shifter rail slightly off the detent ball which holds the shift and fork in its proper position. The shifter fork fingers are then being rubbed against the rotating synchronizer sleeve (think of placing your thumb and forefinger inside the grooves of a small pulley).
Over time the shift fork fingers and the sleeve will wear down. Once the gap is excessive the force applied to the gearset in question (1/2, 3/4, etc) will try to slide the synchronizer inserts inside the sleeve. There is a point of no-return here and the synchronizer hub/sleeve assembly will then try to place itself in the neutral position; a.k.a jumping out of gear.
Old Jul 14, 2015 | 04:00 PM
dbgoodwin's Avatar
dbgoodwin
I don't tend to rest on the shifter, but the handbrake instead. At my driving position the handbrake is absolutely perfect for me to comfortably rest on. One of the many reasons I like highway driving in my car.
Old Jul 14, 2015 | 04:03 PM
Macleod52's Avatar
Macleod52
Mine said off the clutch, brake pedal, and shifter.
Old Jul 14, 2015 | 04:29 PM
rrwirsi's Avatar
rrwirsi
Hand resting on the snifter, just another extended phallus for the ‘boys’ in us.
Old Jul 14, 2015 | 05:14 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I always prefer one hand one my snifter.
Old Jul 14, 2015 | 05:26 PM
johnson-rod's Avatar
johnson-rod
I put my elbow on the windowsill and hold on to the roof.
I even do it in the car.
Old Jul 14, 2015 | 09:12 PM
tcrote5516's Avatar
tcrote5516
[QUOTE=johnson-rod;1590049089]I put my elbow on the windowsill and hold on to the roof.
I even do it in the car.[/QUOTE
It's easy from the second floor but a bitch from the 1st floor isn't it?
To M6: Hand resting on shifter
