[Z06] running 275 vs 265 in front .. issues
Old Jul 15, 2015 | 01:24 AM
LT1driver's Avatar
LT1driver
Default running 275 vs 265 in front .. issues
stock 295 in back, either 265 or 275 x 35 x 18 in front, any issues this will cause....265x35/18 is same diameter as stock 17" tire. would I get understeer, oversteer or ??? thanks.
Old Jul 15, 2015 | 04:17 AM
racebum's Avatar
racebum
stay 265 35 if you can. proper offset and split with a 295 35 18
275 will raise the front a bit and add a very very small amount more grip, both = increased understeer
Old Jul 15, 2015 | 11:29 AM
LT1driver's Avatar
LT1driver
I thought of 275 ibecause there is more sidewall height which give more cushion...265 has less than 4" of sidewall and the 275 has slightly over 4" which is closer to stock 17 inch wheel. don't really want the understeer even though I don't track car, thanks.
Old Jul 15, 2015 | 02:08 PM
C5Dobie's Avatar
C5Dobie
I noticed no difference going to 275/40/17 Nitto NT05, doesn't look weird either
Old Jul 15, 2015 | 02:52 PM
racebum's Avatar
racebum
it's overall diameter i was looking at. 265 35 18 and 265 40 17 have a nearly identical diameter
if you want cushion use a soft sidewall tire like the conti dw. they are a very comfort oriented sport tire and really not all that bad of a performer
very quick tires like the michelin pss has a much better turn in, stability and overall limit, but, they do ride a bit more firm.
my vote is still to get the pss but i will admit the dw is a softer sidewall tire and like going to feel more compliant...keep in mind the drawbacks of compliant sidewalls before you buy
Old Jul 15, 2015 | 11:52 PM
LT1driver's Avatar
LT1driver
I bought the DWs last month and HATE them, to squirmy and unsure feeling for me so going to PSS, tire rack has back order on back tires and discount doesn't list them but will check for me. I mis spoke in that the 265/35/18 has 3.65" sidewall and the 275/35/18 has 3.76 and the stock 265/40/17 has 4.17 sidewall.
Old Jul 16, 2015 | 02:27 PM
95rtturbo's Avatar
95rtturbo
Have you considered Toyo R888s, 275/40/17 fronts, 305/35/18 rears? It may be overkill for your setup, but works well for mine.
Old Jul 16, 2015 | 02:33 PM
JETninja's Avatar
JETninja
WA Events Coordinator
Adding more grip up front means adding more "oversteer"....
Understeer - front loses traction in turns
Oversteer - rear loses traction in turns
All adjustable if you have adjustable sways front and rear...
I have 275's up front, no issues though the sidewall is tad taller then I like visually....
Old Jul 16, 2015 | 02:54 PM
Drewster67's Avatar
Drewster67
I have BFG G Force KDW's all the way around - 275 front and 295 rears ..
No issues
My car is also lowered on the stock lowering bolts as well.
YMMV
Old Jul 16, 2015 | 03:12 PM
BLEKVET's Avatar
BLEKVET
275/35/18 and 305/30/19 is a great combo. Note, this is a plus 1 in diameter arrangement.
Running this on my Z and it is SWEEEET.
Old Jul 16, 2015 | 03:23 PM
dagon138's Avatar
dagon138
It's been awhile since I moved away from the stock sizes but you'll notice more of a difference just on the fact that you replaced the tires. It doesn't change the car really IMO.
Now I used NT05 for a long time (275/295) but recently moved to R888 (275/305).
With the 305 rear I swear it's feels softer.
Old Jul 16, 2015 | 05:16 PM
racebum's Avatar
racebum
i can't believe i made that mistake. you're correct on the grip at least
raising the front height will add understeer which must have been the thought on my mind when i said those two things
Old Jul 16, 2015 | 05:19 PM
JETninja's Avatar
JETninja
True, but I lowered mine for a slight rake...so no issue there......
Old Jul 16, 2015 | 05:31 PM
TXGS507's Avatar
TXGS507
I am running the 275/35 18 up front and 345/35/18 out back.. Love how they look, feel, handle.... Just my .02..
Old Jul 17, 2015 | 10:35 AM
Fast Cop's Avatar
Fast Cop
Same here. Went with the NT05 at 275/40/17 and no issues at all.
Old Jul 17, 2015 | 11:14 AM
danziger's Avatar
danziger
I have the PSS 275/18s up front...no issues at all and a great tire.
Old Jul 17, 2015 | 02:06 PM
Fast Cop's Avatar
Fast Cop
Here is my 04 Z06 with NT05's all round in the 275/295 17/18 combo.
To running 275 vs 265 in front .. issues
Old Jul 17, 2015 | 02:38 PM
Breze84's Avatar
Breze84
I am running 275/35/18 up front, But I am running 305/35/19 DR's out back soooo I don't know how much this would help you. But It rides perfect, I am assuming you are worried about the TC going wacky because of the tire heights! As long as you keep it over a 1/4 taller out back you are fine...
Old Jul 17, 2015 | 05:30 PM
racebum's Avatar
racebum
there isn't one. this is absolutely the best 275/295 combo for the z06. the 275 is slightly short and the 295 slightly tall making it nearly identical to the 265/295 OE tires in height, the nt05 is just a hair wider up front but the square sidewall gives the appearance of a perfect fit
100% my vote for someone wanting a cosmetically correct OE replacement tire on the c5z. before i went 19/18 for the pss i was considering the nt05 simply because they look so good on the stock wheels and are 90-95% of the performance of the slightly undersize 285/255 hankook rs3
sure the DW is better in rain but it is much less responsive & worse in the dry
Old Jul 17, 2015 | 06:25 PM
FASTFATBOY's Avatar
FASTFATBOY
I run 275/35/18 in front a 9.5 wheel and a 295/35/18 rear on a 10.5 wheel, tires are a Michelin PSS.
I had the Conti DW, hated them....felt like marshmallows. Sent them back to Tire Rack.
My car feels balanced, if you don't track the car and have that set of senses tuned very high I doubt you would notice any push(understeer) on the street unless you had badly mismatched tires.
