low oil warning
Jul 15, 2015 | 12:57 PM
low oil warning
Can a low oil warning keep the engine from starting?
Jul 15, 2015 | 10:09 PM
Quote:
Originally Posted by
8VETTE7
Only if the engine is already seized from previously running the engine with insufficient oil.
What exactly are your NO START symptoms??
Cranks but will not run???
NO Crank???
No Crank but sometimes yes but sometimes no.
Jul 16, 2015 | 06:35 PM
The codes are as follows: 28TCS: C1214HC, C1225H, 1226H, 1276H, 1278H, 1283H, U1016H
40BCM: B2573H, B2592H, B2721H, 2723H, U1016H
99HVAC: B0361HC
AO-ADCM: B2282, B2284H, B2264H, U1064H, U1016H
A6-SCM: B2607H, B2860H
BO-RFA: C2100HC. C2110H, CX1255H, U1064H, U1016H
10PCM: P0440C, P1431HP1631HC
As far as the security light it isn't acting up now so I don't know what it was doing.
Any help with this problem will be greatly appreciated. Tom
Jul 16, 2015 | 07:18 PM
All those Uxxxx codes usually mean a bad battery...get it fully charged, clear codes and try again.
The P1631 code means the BCM and PCM are out of synch with respect to the valid security code, so that's your no-start issue. They should get back into synch once you've got a good battery.
If not, there's a resynch process, but I'm not going to type it in until you have a good battery: (1) it's complicated and (2) it's really intended for situations where the PCM and/or BCM were replaced.
Jul 16, 2015 | 07:33 PM
8VETTE7
... Once the battery is KNOWN good I would clear all the codes that you have (see the video for how to clear them) and then drive the car ....
Uh, did I miss something? I thought his problem was that he couldn't start it...
Jul 16, 2015 | 07:58 PM
8VETTE7
I would say yes.
A low/bad battery is the most likely cause of his problems IMO. Once that is corrected I expect the car will start and be drivable.
Ok, we're back on the same page...just didn't sound right to have to drive the car to diagnose a no-start problem.
Jul 16, 2015 | 11:21 PM
Reminds me of something. The c3 was set up that way. It wouldn't start if the oil pressure was below a certain level, at least on the later ones.
Jul 17, 2015 | 02:53 PM
Useful information everyone. Thanks.
