Door reflectors falling out
Old Jul 16, 2015 | 08:24 AM
wcsinx's Avatar
wcsinx
Default Door reflectors falling out
Anyone else have this happen?
Seems like years of shutting the doors finally snapped off those 2 little plastic tabs that hold them in. My driver's side came out about 2 years ago, and the passenger side followed suit last month.
I'm asking because I devised a $1 Harbor Freight solution that works perfectly, is undetectable, and still allows for easy removal. I'll post up pics if there's any interest.
Old Jul 16, 2015 | 08:32 AM
Phanni's Avatar
Phanni
There's always interesting inexpensive fixes.
Old Jul 16, 2015 | 11:39 AM
wcsinx's Avatar
wcsinx
45 views and only 1 reply?
Well anywho, I got these magnets...
http://www.harborfreight.com/pack-of...ets-97504.html
Step 1: I melted out a slot for one of them in the block of styrofoam behind the reflector using a wood chisel heated with a torch. I made it just deep enough that the magnet sits flush with the foam.
Step 2: Used a 2 part epoxy to secure the magnet in it's slot
Step 3: Once the epoxy cured, I stuck the other magnet on top of the one in the foam, sanded the back of the reflector a little to roughen it, put a thin layer of epoxy on the back of the reflector, and then "installed" the reflector in the door. This left the impression of the unsecured magnet in the still wet epoxy on the reflector.
Step 4: Pull the loose magnet back off and push it into the impression it made in the epoxy on the reflector.
Then just let the reflector epoxy cure and install it as normal. These magnets are plenty strong enough to hold the reflector tight through a door slam, but not so strong that you'll tear out the one in the foam if you ever need to remove the reflector.
I'm not sure if these steps are clear, so I'll post a pic or two tonight.
Old Jul 16, 2015 | 11:48 AM
LoneStarFRC's Avatar
LoneStarFRC
The least expensive I've found is to pry them out correctly to start with. Either, or both, "L" shaped tabs get snapped off from trying to pry the reflector off the door by prying on either end, or (worse) prying from the top.
Always pry from the bottom center and no worries.
Old Jul 16, 2015 | 01:02 PM
wcsinx's Avatar
wcsinx
Mine had never been removed so there goes your theory. The one and only time I've needed to access that bolt, I had the whole door panel off. Yet the tabs still fractured simply from years of door closings.
Old Jul 16, 2015 | 02:02 PM
Way to think outside the box when it comes to fixing broken things on the car. Thanks for the tip.
Old Jul 16, 2015 | 02:11 PM
2FAS4UU's Avatar
2FAS4UU
I added LED's to my reflectors to make them functional !!
Old Jul 16, 2015 | 04:51 PM
Choreo's Avatar
Choreo
My tabs broke off and I tried a couple different fixes (superglue, epoxy, etc. -) none lasted. Finally, used a couple small washers the size if the missing tabs and screwed them into the back side (offset to simulate tabs) - screws and washers all metal. Worked perfect and a free fix from my parts bin.
Old Jul 16, 2015 | 06:44 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
Just one of the reasons I get livid when people slam my doors!!!
DSTURBD
To Door reflectors falling out
