Fuel fill problem
Old Jul 20, 2015 | 10:54 PM
Brano53's Avatar
Brano53
7th Gear
Default Fuel fill problem
I have an early year date 2003 C5 which I brought back to Australia and the fuel flow from Gas station pumps must be higher here than in the USA i.e. I think the rate here is 40+ lpm. Consequently it can take me forever to fill a tank as the pump keeps shutting down (some stations better than others). Is there any thing that can be done to the car to accept the higher flow rate from Gas pump?
Old Jul 20, 2015 | 11:03 PM
cmiller8006's Avatar
cmiller8006
What if you just don't squeeze the handle as hard?
Old Jul 20, 2015 | 11:09 PM
Brano53's Avatar
Brano53
7th Gear
Yep do that but it does not always work. If there is no setting or adjustment that can be made to the car then I will have to live with it as I have been doing. Just wanted to be sure I was not suffering unnecessarily.
Old Jul 21, 2015 | 02:32 AM
Deneb's Avatar
Deneb
My C5 2004 does the same at the Mobile pump. Still searching for a solution.
Old Jul 21, 2015 | 02:39 AM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
I have found that mine fills more easily, without shutoffs, if I put the nozzle in just far enough to catch the first couple of loops on the surround spring on the nozzle. If I put it all the way in, it shuts off repeatedly.
You might try this?!??
DSTURBD
Old Jul 21, 2015 | 03:42 AM
ronwc's Avatar
ronwc
That's what she says.
Old Jul 21, 2015 | 04:09 AM
torchredmadness's Avatar
torchredmadness
When we first tried to fill our '03 coupe with gas it shut off constantly. I did my research on the forum and found out that if you insert the gas nozzle and rotate it 90 degrees to the right (rear) it will fill with no problem. As soon as it shuts off I'm done. Every time I have tried to top off I have smelt gas in the cabin. Every time!
Old Jul 21, 2015 | 04:53 AM
ZigZag's Avatar
ZigZag
DSTURBD
I found this to work so much better.
Old Jul 21, 2015 | 06:24 AM
SIUSIU's Avatar
SIUSIU
rotate 45 to 90 degrees works for me
Old Jul 21, 2015 | 11:47 AM
tacman's Avatar
tacman
St. Jude Donor '13
Have your mechanic check the evap system. If that "clogs" up, the pump will shut off if gas flows quicker than the fumes can be evacuated through the evap system.
Old Jul 21, 2015 | 11:55 AM
imlowr2's Avatar
imlowr2
I recently bought my 2001 and had the same problem the first time I filled it. It kept shutting off. After playing with it for a while, I managed to get slightly over 3/4 tank of gas. The guy who sold the car to me gave it to me on fumes. The gas pump and nozzle wasn't that big of deal, but finding out how to open the gas lid was more than frustrating. If it wasn't for the internet or finding another Corvette owner, I'd still be at the gas station looking for the release button.
Old Jul 21, 2015 | 01:44 PM
Deneb's Avatar
Deneb
Yeah, but did you ever fill the tank completely?
My Volvo s60, has a small tube under the trunk that clogs and makes the gas not go in. Mechanic said blow air in the tube every year to clean it. It works, but I wonder if I'm sending dirt into the gas tank?
Old Jul 21, 2015 | 10:27 PM
Here was some info that was posted on the forum a while back. Might be worth checking into.
File Type: doc
Old Jul 22, 2015 | 03:27 AM
Odinson's Avatar
Odinson
I had the same problem the first time I tried to fill mine. Kept kicking like it was full. I found if I rotate the nozzle upside down it works perfect.
Old Jul 23, 2015 | 01:35 AM
Brano53's Avatar
Brano53
7th Gear
Thanks to you all. I will try some fuel nozzle realignments and if no joy I will locate best pumps and stay with that gas station. Your comments are appreciated.
Old Aug 11, 2015 | 11:46 PM
Deneb's Avatar
Deneb
Sticking it in half way totally worked for me! Please no jokes. okay, please some jokes.
Thanks for the great advice.
Old Aug 12, 2015 | 09:25 AM
Black 02's Avatar
Black 02
Same here. Sometimes I have to give her just the tip at my local Exxon station or she complains too much.
To Fuel fill problem
