replacing stock cats
Old Jul 21, 2015 | 12:03 PM
jimih941's Avatar
jimih941
Default replacing stock cats
I just purchased a set of long tube headers that weld up to the front of the stock catalytic converters (JBA headers). I also purchased a set of high flow cats to replace the stock units. From looking at the stock units, it appears the inlet and outlet are offset, meaning they if I put in an aftermarket cat it doesn't look like I can run a pipe straight to the X-pipe, it would have to be bent to come back into the center. Am I looking at this wrong or can someone recommend the proper bend in a pipe that would connect the high flow cat with the x-pipe?
Thanks!
Old Jul 21, 2015 | 07:31 PM
T5Mika's Avatar
T5Mika
https://www.corvetteforum.com/forums...installed.html
