Driver Side Window Control not lowering passenger window
Old Jul 21, 2015 | 03:42 PM
csc67's Avatar
csc67
Default Driver Side Window Control not lowering passenger window
I own a YR 2000 vette and the driver side window control unit won't move the passenger window up or down - It used to work occasionally, but hasn't worked for a week straight now
What is the solution(s) to fix this issue?
Old Jul 22, 2015 | 09:18 AM
dadaroo's Avatar
dadaroo
Can you move the window from the passenger side door switch?
Also please pull your dash DIC codes to see what shows up.
Mr. Sam
Old Jul 22, 2015 | 09:21 AM
csc67's Avatar
csc67
Mr. Sam,
Great question - The passenger side works perfectly - I'll check codes and respond back
Old Jul 22, 2015 | 10:26 AM
cmjuhl's Avatar
cmjuhl
Remove drivers side switch and check for power at the switch connection. If you have power at the connection you need a new switch. Just my .02
Old Jul 22, 2015 | 12:08 PM
csc67's Avatar
csc67
I have an update - The passenger window will sometimes moves up or down, but I have to press VERY hard
Old Jul 22, 2015 | 01:36 PM
cmjuhl's Avatar
cmjuhl
Sounds like bad switch.
Old Jul 22, 2015 | 01:39 PM
Nate@VanBortelChevy's Avatar
Nate@VanBortelChevy
Platinum Supporting Dealership
Agreed, sounds like a bad switch
Old Jul 23, 2015 | 06:39 AM
dadaroo's Avatar
dadaroo
I don't have enough information to say the passenger switch is the problem.
If it is a problem, then it does not explain why the driver side cannot operate the window at all. The drive side control does not use the passenger switch in the circuit.
asx67, you owe me the codes. We need to fix what is wrong at the passenger door and then see if that resolves control from the driver side.
I have several ideas on what the issue may be but I want to start with codes.
Can you use a multimeter to measure resistance and voltage?
Let's try not to throw parts at the problem without knowing what is wrong.
Mr. Sam
Old Jul 23, 2015 | 06:13 PM
ZFLASH's Avatar
ZFLASH
St. Jude Donor '10-'11-'12-'13-'14, '16
Good news,bad news, the problem (which is the good news) is you need a new passenger electric modulator. The bad news is they don't make them anymore,but your dealer might have one on the shelf for $385.00, or you can call Marc at Vettnuts and get one used. Now that being said,I've gone through 3 used ones which would have been the cost of a new one. If you can take your door panel off,it's very easy to change,2 bolts and 3 plugs.Just make sure you get the same part # ( mine is 09389699) because if you mix them you might mess up your electrical system. Now if you can afford it,Gene Culley has new remakes, but you have to get both sides,roughly a little over $900.00. This is a common problem on the C5's they say because the passenger window doesn't get used enough,but I put mine down all the time,so go figure. Sorry for being long,hope this helps you out. Marc's # is 615-896-6100,good luck. L8R ZFLASH
Old Jul 24, 2015 | 06:39 AM
dadaroo's Avatar
dadaroo
It is amazing that people can tell you what the issue is without your having performed any actual diagnostics.
Old Jul 24, 2015 | 09:37 AM
Lee DeRaud's Avatar
Lee DeRaud
...in principle, but at least the way I read posts #3 and #5, I think he meant the passenger-side switch works fine and he can sometimes get the passenger window to move by pushing the driver-side switch very hard.
Old Jul 24, 2015 | 09:47 AM
Lee DeRaud's Avatar
Lee DeRaud
Originally Posted by ZFLASH
Good news,bad news, the problem (which is the good news) is you need a new passenger electric modulator. The bad news is they don't make them anymore... Now if you can afford it,Gene Culley has new remakes, but you have to get both sides,roughly a little over $900.00.
Leaving aside the fact that the window works fine from the passenger-side switch...
I could have sworn that there was a thread in the last month or two from some vendor here (not Gene) who had new clone regulators for a rational price.
Old Jul 24, 2015 | 10:16 AM
dadaroo's Avatar
dadaroo
Thanks Lee, I may have misunderstood what switch he was referring to when he corrected his prior information.
I am still interested in diagnostics unless the OP wants to throw parts at the issue. I am still waiting on codes.
OP, you need to clarify the issue on the switches.
Lee, Did you mean clone regulators of door modules? There are suppliers of non GM regulators out there.
Old Jul 24, 2015 | 11:14 AM
Lee DeRaud's Avatar
Lee DeRaud
Regulators, not door modules. Like I said, it was a forum vendor, and as I recall the price was low, like ~$100.
Then again, I'm old, and a quick-and-dirty search didn't cough it up.
[EDIT: Ok, I see what happened...I misread "modulator" as "regulator" in post #9. Regulator is the mechanical scissor-arm and motor assembly, right?]
Old Jul 25, 2015 | 12:22 AM
ZFLASH's Avatar
ZFLASH
Lee and Dadaroo, I get them confused too, I mean the little black box located right below the door handle. This box doesn't throw codes, my old ones wouldn't work, then when taking it out and laying it sideways it would work. It was getting power,it's just something on the circuit board wasn't making good contact anymore. Sorry if I ruffled some feathers,I was just speaking from my past experience with this issue. Thanks guys,L8R ZFLASH
Old Jul 25, 2015 | 01:02 AM
bad man Barry White's Avatar
bad man Barry White
St. Jude Donor '16
I had this very thing happen yesterday. I ended up pulling the boot between the door and pillar back, and moving the wiring around while pressing the button. The pins at the connector were loose. I ended up fishing them up and tightening them up on the female side for a stronger connection. I got this info from performing a search in the tech section.
Old Jul 25, 2015 | 02:05 AM
Lee DeRaud's Avatar
Lee DeRaud
Ok, got it. Not quite sure what you mean by "doesn't throw codes", as there are a whole pile of them in the B22xx range related to those two modules (LDCM and RDCM). Now if one of them is completely dead, it would also take out things like mirror control and door lock on that side: it controls more than just the window.
To Driver Side Window Control not lowering passenger window
Old Jul 25, 2015 | 06:48 AM
dadaroo's Avatar
dadaroo
No we're all fine, just trying to help the guy.
Each door does have a Door control Module and they are on the serial bus. Actually the driver side uses the serial bus to operate the passenger side. That saves wiring and weight.
There have been lots of issues with the connector in the door A-pillars that have caused serial bus issues. Each module can throw lots of codes since it also keeps mirror control features.
Old Aug 12, 2015 | 09:19 PM
csc67's Avatar
csc67
No codes are being 'thrown' except a tire pressure sensor
The passenger side window always works - The driver side control unit that controls the passenger window works occasionally - When the driver side window control is able to lower the passenger window, I have to press the down button very hard for it to work
Thanks for the effort to resolve this
Old Aug 13, 2015 | 06:23 AM
dadaroo's Avatar
dadaroo
Sure sounds like the driver side switch is the problem. I would remove it and test the contacts or jumper the connector pins to see if the right window works OK. Could be the driver door module but the switch is more likely based on what you said about having to press the switch so hard.
