[Z06] pulled the DWs off car
Old Jul 25, 2015 | 12:24 AM
LT1driver's Avatar
LT1driver
Default pulled the DWs off car
left front on and pulled back ones and took back, put old worn out tires back on and guess what......some of the wiggle/mushy feeling gone on curves, any thoughts on this?
Old Jul 25, 2015 | 01:58 AM
grantv's Avatar
grantv
Sure, I have thoughts...
What are the old tires? How bald are they? Dry, wet driving or both? Didn't give us a lot of info to build on.
Old Jul 25, 2015 | 09:29 AM
His93C4's Avatar
His93C4
I hated the conti dw. Horrible feeling tires. I switched back to new Bridgestone re760s
Old Jul 26, 2015 | 01:56 AM
LT1driver's Avatar
LT1driver
old tires...265/35/18 front and 295/35/18 rear, bridgestone zri and firestone respectively, other than left front inner wear down to 2/32, others 4/52-6/32 but are 2008-2010 tires so time alone dictated I replace them. I am going to order 275/35/18 super sports for front and 295s for rear and await back order. car used in town 90% of time so old junk should be ok until new tires come in.
Old Jul 26, 2015 | 02:09 AM
grantv's Avatar
grantv
Maybe it's the low tread you like partly...
Old Jul 26, 2015 | 09:58 AM
firebirdfan's Avatar
firebirdfan
Continentals have SUPER soft sidewalls. They're built for comfort more than anything. They're a great tire if you're going to go long distances, they handle adverse weather very well, and they hold up fairly well in terms of longevity (mileage). However, they will not do well with any sort of turning. Guys at the local autocross have to pump their tires up to 45 psi just keep the sidewalls from rolling.
Only way I'd run them would be with a very short aspect ratio for the sidewall. It'd be about the only way to keep the flex under control.
Also, depending on what tire your replaced it with can make a huge difference. Hopefully you didn't put runflats on the car. Runflats always have crazy stiff sidewalls. This make the car feel very planted because it responds so quickly to inputs, but your total overall grip is massively reduced.
Old Jul 26, 2015 | 10:19 PM
LT1driver's Avatar
LT1driver
runflats no way, plan to put 275/35/18 michelin super sports on front and 295/35/18 on back whenever france gets around to producing some OR nitto invo in same size so I can drive on a trip in late august.... opinion on this??? thanks in advance.
Old Jul 27, 2015 | 09:55 AM
danziger's Avatar
danziger
You will love the Michelin PSS. I didn't consider the Invo because there was so many poor reviews. The Nitto NT-05 was a contender, but my friends with Vipers sold me trying Michelin.
Old Jul 27, 2015 | 08:28 PM
LT1driver's Avatar
LT1driver
danziger, what bad things did they have to say about the invos, you can pm me if you would prefer...thanks.
To pulled the DWs off car
