Reverse Light Problem
Old Jul 25, 2015 | 07:22 PM
striper's Avatar
striper
Default Reverse Light Problem
I'm not sure how long this will be but bear with me, I need help. I recently installed a Kenwood DNX691KD in my car. It also has a Pyle reverse camera which was working great. I started to have the camera work intermittently. Then it totally stopped working. I figured I'd get around to checking it out at another time, since I initially had problems with the RCA cable causing the camera not to work. So I'm walking away from my car and I press my remote to lock the car and only the left reverse light flashed. The right one is where I have the camera wire tied in. I figured that my connection broke and I'd fix it later. The wire joint had come apart rendering the right side light inoperable. I reattached the connections and now I have no reverse lights at all, and no camera either. There are no fuses in the reverse light circuit, only a relay in the engine compartment fuse box. When I checked the DIC for codes I get a code for the relay, B2482 H C. I have tried two other working relays and nothing happens. I put my relay in my friend's car and his lights work. I am now baffled. What else could I have screwed up? I tried locating the ground but no luck. I am going to try grounding the lights to a new location. BTW, all other rear lights work as they should. The approach light function of all other lights also works, minus the reverse lights
Old Jul 25, 2015 | 07:30 PM
Sourmug's Avatar
Sourmug
Here's a coupe of threads that might point you in the right direction:
https://www.corvetteforum.com/forums...dont-work.html
http://www.corvetteactioncenter.com/...ing-my-c5.html
Old Jul 26, 2015 | 07:27 AM
dadaroo's Avatar
dadaroo
Relays are for control and not circuit protection. Fuse 21 in the I/P fuse box is for that circuit. Also Fuse 2 in the engine fuse box is for the relay coil and it could be bad.
If you are blowing that fuse due to the camera load don't put in a larger fuse. You will need a seperate feed.
Old Jul 26, 2015 | 02:32 PM
striper's Avatar
striper
I have not blown any fuses and the relay is good, I checked that already. This is why I can't figure out my problem.
To Reverse Light Problem
