I did a search and only found threads from 2006 and 2007. So I figured I would post a new thread. I also tried to take apart some old sensor with not much luck. The older ones would have been easier to take apart since the battery is on the side and not above the circuit board. I did successfully take a couple of them apart but do I trust them to work. Not really, I would rather have new ones, have them installed and the wheels balanced and be done with it. Much better than spending the money and having one fail a month down the road. Thats my .02
So I thought I should ask where is the best place to purchase new ones these days. There should be others here that should be having the same problem since the car is 13 years old now. Man, how time flies. It is still a great car and I still like it more than the new ones. Anyway I hope that someone can help me out here. Thanks in advance.
Might want to make sure that TPS is the right one for your car. I plugged in my '03 (which should use the same sensor as your '02) and it said it would not work.
It's the correct one for '00-'04. Amazon's "does it fit" app says no for "hatchback" and yes for convertible, probably a glitch in their database.
Note that it also says yes for Z06...did the (non-runflat) Z06 even have the sensors installed from the factory?
Originally Posted by thisMSGgood4me
No, they did not.
It's starting to look like they got the entries for "Z06 2-door Coupe" and "Base 2-door Hatchback" reversed. Wonder how many other parts have this problem.
(And I guess technically they "fit" the '00-'04 Z06, since it uses the same receiver and wiring, but as I recall you'd have to get the BCM programmed to enable TPMS.)
