[Z06] 01 PUP CATS
Old Aug 20, 2002 | 07:46 AM
maticam's Avatar
maticam
Default 01 PUP CATS
hAS ANYONE TAKEN OFF THE PUPS CATS ON THE 01>>> IF SO DID YOU GUT OUT THE CATS OR JUST CUT THEM OFF ???
Old Aug 20, 2002 | 08:19 AM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: 01 PUP CATS (maticam)
I removed them on my 01; they have to come off to install long tube headers.
Old Aug 20, 2002 | 11:19 AM
VettTheRipper's Avatar
VettTheRipper
I gutted mine. Simply remove the exhaust and dig out the catalyst with a screwdriver. You'll also have to make a homemade tool with a 90 deg. bend to get all of it out. Be sure to use a leaf blower to clean the pipes out before reinstall. This is a great mod. Noticable difference in sound and power.
Gutting them caused no problems.
[Modified by VettTheRipper, 3:19 PM 8/20/2002]
Old Aug 20, 2002 | 05:13 PM
GaryZ06's Avatar
GaryZ06
I had mine cut off and a straight pipe welded in.
Old Aug 20, 2002 | 06:18 PM
Zee Freak's Avatar
Zee Freak
St. Jude Donor '03-'05-'06
Will the car still pass DEQ without the pups, and with the stock 01 main cats still on? Or do you need the 02 cats to pass?
Old Aug 21, 2002 | 01:45 PM
maticam's Avatar
maticam
Default Re: 01 PUP CATS (Zee Freak)
In SC there are no state inspection at all. that is the only thing good about the state>>> hehehe :smash:
Old Aug 21, 2002 | 02:37 PM
tjfees's Avatar
tjfees
Default Re: 01 PUP CATS (VettTheRipper)
I gutted mine. ... Be sure to use a leaf blower to clean the pipes out before reinstall. This is a great mod. Noticable difference in sound and power.
Did mine, too. Just make sure to blow the stuff "forward" and not clog the main cats - or use a shop vac. :)
Old Aug 21, 2002 | 10:46 PM
maticam's Avatar
maticam
Default Re: 01 PUP CATS (tjfees)
thanks to all you all have been very helpful :seeya
Old Aug 22, 2002 | 12:27 PM
Zee Freak's Avatar
Zee Freak
OK what about those of you that do have to go thru DEQ?
Old Aug 26, 2002 | 02:45 PM
tjfees's Avatar
tjfees
... In SC there are no state inspection at all. that is the only thing good about the state ...
Just make sure the engine and exhaust are up to operating temperature just before any inspection. The precats "prelight" the exhaust mixture when the system is cold to reduce emissions until the main cats heat up.
The 02s have a different main cat that does the job with no precats.
To 01 PUP CATS
