Injectors -- compatible between years?
Old Aug 3, 2015 | 01:19 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default Injectors -- compatible between years?
Quick question:
Are C5 injectors of any certain year compatible with all other year C5s?
Old Aug 3, 2015 | 02:37 PM
tlove32's Avatar
tlove32
They're all compatible. The Z06's had slightly bigger (volume-wise) injectors than the base model LS1's.
Old Aug 3, 2015 | 03:23 PM
phoneman91's Avatar
phoneman91
Originally Posted by Tusc
Quick question:
No.
Old Aug 3, 2015 | 11:04 PM
Originally Posted by phoneman91
No.
Would be more helpful if you gave an explanation for your answer.
Old Aug 4, 2015 | 01:57 AM
phoneman91's Avatar
phoneman91
Per "C5 Corvette Book of Knowledge", page 7,8,9:
1997-1998: 28 pounds per hour injector
1999-2000: 26 pounds per hour injector
2001-2004 28 pounds per hour injector
A search of part numbers for each model year,from more than one source--- would verify if this is correct or not .
Old Aug 4, 2015 | 10:10 AM
jackthelad's Avatar
jackthelad
I do know the early cars (97-98) had bigger injectors, as Lingenfelter charged extra for his first twin turbo kits when installed on later cars as he had to "upgrade" them to the earlier injectors.
BTW, I've always understood that's the reason early cars get more benefit from a CAI system than later ones - look at the K&N web site for their dyno numbers as an example.
p.s. Wouldn't it be great if all CAI vendors published actual dyno results? It would get rid of a lot of the mythology out there.
To Injectors -- compatible between years?
