Shifter Boot Install
Old Aug 6, 2015 | 02:35 PM
Vinny 2001's Avatar
Vinny 2001
Default Shifter Boot Install
I am not the first owner of my Vette but definitely the last Anyway the previous owner replaced the shifter boot with an after-market boot and I now realize it is missing the metal retainer ring, which is why it's been pulling up from the bottom.
Question on the ring install, I see a few differing instructions on the web where one has the bottom of the boot wrapped around the ring, and another does not use the ring at all. In each though the boot is glued or otherwise fastened to the
What is the correct way to do this. Does it need to be wrapped around the metal ring and clipped to the cup, or should it be glued directly to the cup?
Added a picture of what Vette Essentials shows.
Thanks,
Vinny
Old Aug 6, 2015 | 07:25 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Thanks,
Vinny
I've changed out my shift boot several times and also change the original plastic retainer ring to a metal wire retainer. Both systems use the same method of attachment to the shift boot. The shift boot should have corresponding holes that line up with either the plastic ring clips or the metal wire hooks. That's all there is. It's a compression fit.
Old Aug 6, 2015 | 07:29 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
The plastic ring in the picture is what the car comes with. My understanding is the plastic ones are no longer made, hence the metal ones. They are not used together.
Old Aug 7, 2015 | 04:25 AM
LoneStarFRC's Avatar
LoneStarFRC
True story.
P.S. the plastic retainer ring was never available as a separate item. It only comes on the shift boot assembly and it is crap.
Use the aftermarket metal retainer.
Old Aug 7, 2015 | 08:12 AM
Vinny 2001's Avatar
Vinny 2001
Thanks guys, helpful info. I think i get the idea now and I should be able to work it out. Ordered the metal replacement ring.
Old Aug 7, 2015 | 09:16 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Where does one order the metal ring?
Old Aug 7, 2015 | 09:25 AM
Vinny 2001's Avatar
Vinny 2001
i found this on Ebay.
http://www.ebay.com/itm/Shift-Boot-C...-/220850286432
Old Aug 7, 2015 | 09:40 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Thank you. I am now #258 sold.
Old Oct 13, 2015 | 12:43 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
FWIW, I recently bought one of those retainer rings.....terrific piece!
Old Oct 13, 2015 | 07:14 PM
Heck of a lot better than the plastic piece that tends to break over time.
Old Oct 13, 2015 | 10:52 PM
rkdc5z06's Avatar
rkdc5z06
Im using one off ebay for $10. it is actually for a Honda Civic. It works great.
Old Oct 14, 2015 | 08:07 AM
leadfoot4's Avatar
leadfoot4
Do you mean the shift boot, or the retaining ring?
To Shifter Boot Install
