Exterior Temp Reading
Old Aug 7, 2015 | 12:12 PM
krm_wi_C5's Avatar
krm_wi_C5
Default Exterior Temp Reading
I have a '98 convertible and have noticed this year that my exterior temperature readings have been off, mostly when it is very warm outside. The reading usually is around 20 degrees off to the cooler side when it is in the mid 80's or above. I have a read a few posts that refer to the sensor located in the lower front near the radiator. Just wondering if anyone else has had this issue, and what you did to remedy it. Thanks in advance for any info!!
Old Aug 7, 2015 | 01:38 PM
twill's Avatar
twill
Default Me too!!!!!!
I am having the same problem but mine reads hotter than it is, if the temp is 70 my gauge says 80.
Old Aug 7, 2015 | 01:41 PM
runner140*'s Avatar
runner140*
Ambient temp. sensor. About $12. to $15.00 and about 5 minutes.
Old Aug 7, 2015 | 02:25 PM
65GGvert's Avatar
65GGvert
Try disconnecting the plug near the sensor and clean the contacts. It's up there where it gets a lot of water and grime. If it doesn't work, try the sensor.
Old Aug 7, 2015 | 10:17 PM
Pretty easy to replace the sensor.
Old Aug 7, 2015 | 11:13 PM
RBBrimer's Avatar
RBBrimer
My temp would read high my HUD would not stay on gage (I would have on fuel)on next start it would change. New battery, every thing OK now. I also had clicking on start up(starter or battery??)Changed battery, got an Optima red top from Amazon $150.00 free shipping two day. Advance Auto $220.00. Everything GREAT now..
Old Aug 7, 2015 | 11:32 PM
Choreo's Avatar
Choreo
Mine read 107-Degrees today - unfortunately it was dead-on!
Old Aug 7, 2015 | 11:45 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
Had the same problem with my previous '99. Eventually, your AC will quit working due to this bad sensor. Took mine in to the dealer expecting hundreds of dollars in repairs. They called me in about fifteen minutes later...........all fixed.......about $18.00 total bill! And that was at a dealership!!!!! I was pleasantly amazed as I thought it was going to ruin my trip to Cruise-In V at the museum in the next few days!!
And that is the ONLY pleasant dealer experience I have ever had!!
DSTURBD
To Exterior Temp Reading
