New Calipers - Duralast?
I used Duralast a lot on my daily and the "fleet" (I go take care of my folks' cars, too) and have had no complaints on any of various products they make.
Not that I need new calipers. The car has about 60k on it. But I want to get a set painted red to match my new FRCs and it's easier to have a second set to give out and then install than to leave the car out of service and up in the air for a week or two.
Just a suggestion to save some money.
A month ago I had a right front hub on my car start to go bad. Clostest place that could fix it to where I was at the time was a Firestone dealer. Had them put a hub on, all they could get was Duralast.
8 DAYS later, the brand new Duralast did this https://video-mia1-1.xx.fbcdn.net/hv...e0&oe=55C8E3DA
Only 8 days. Pitiful.
If you insist on changing, don't fear Duralast. They regularly provide long or even lifetime warranty on their products and it's the only brand replacement part I will buy (as long as it's available). While that video might be scary, there are too many factors to determine that the Duralast part was to blame... I have been running Duralast on mine for the last 5 years without any problems at all.
Good luck, have fun painting
We took a brand new hub out of the box and mounted it on the car, taking time to properly torque the bolts and the caliper hardware. I drive the car 5 miles to work and 5miles back every day. The Duralast hub that came off the car was so loose I could hold the mount surface and rock the wheel mount surface with my bare hands.
I really really want to know what "other factors" are at work here.
It's great that a hub you bought 5 full years ago has held up. Happy for you. But I really want to know what "other factors" went into this hub lasting only 75 miles and would cause you to totally ignore the evidence of your own eyes and advise someone to ignore it out of hand.
As for the warranty? Make sure you don't throw away the boxes. If you do, and you try to return them in the Delco boxes that came in the hubs you bought to replace the junk Duralast hubs you will be DENIED and told "not our parts".
Great warranty, isn't it?
Video not working.
The "Autozone Police" must be on patrol.....
I'm not trying to convince you to use Duralast parts, if anything buy another brand you trust, even if it's for peace of mind. All I was trying to get at was that you shouldn't shy away from a brand (if you like it) because of a faulty part you got.
Regarding these "other factors" I must have missed the part in the original post where it was stated that it was properly torqued down to spec, greased adequately, road tested to apply a good amount of strain on the part etc... Also, I apologize but there are a lot of C5 owners out there that drive their car oblivious to the needs of the vehicle itself, and even the road its driven on; not saying you are one of those drivers, but how would I know?
This all said, that doesn't excuse the part breaking and that is the down side to having to do maintenance while away from home. My personal opinion is that the Firestone tech messed everything up, because everything Firestone I have ever had has broken down ridiculously fast just like their tires
As noted before... something ridiculous can be found with any mass produced item there is, doesn't make the whole brand terrible. If I needed a tire and Firestone fit my budget I would still pick them any time. As for shop's, I just have terrible luck so now I do the work myself.
