[Z06] gas gauge says im empty
Did the car come with any kind of warranty? I'd notify them immediately as the car had issues mere hours after you bought it. It is generally a fuel sender unit and as others have stated, there is plenty of reading on the subject. If there is any kind of warranty, the dealership should fix it. If the dealership won't help, try the Techron route.
What year is your car? You don't have to drop the tanks if your car is a mid '03 or older. If newer, then I agree you will need to drop the tanks.
Lastly, welcome to the forum. There are plenty of people who can help you with diagnosing / fixing your car. If you're the least bit handy, you can do quite a bit of your own work and save a considerable amount of $$$$. As an example, if your car is a mid '03 or older, the level of difficulty replacing the fuel sending units is about equivalent to changing a tire.
The process is actually fairly easy. I have a 2003 Z06 non FFS system so the process should be similar if not the same.
1) Run or empty the tanks down as close to empty as possible. I drove mine to get the fuel level down. I used my odometer to track my mileage and then had a gallon can of gas in the car in case I ran out. (didn’t need it)
2) Disconnect the battery
3) Jack the rear of the car up and remove rear wheels (remember to chock the front wheels and use jack stands)
4) Remove the aluminum cover on the rear of the tank (IIRC one nut and one bolt)
5) Disconnect fuel lines and electrical connector
6) Remove the six bolts holding the fuel pump assembly
7) Remove fuel pump assembly. I recommend starting with the right side (passenger side) to become familiar with the process. The right side is the siphon / jet pump side and will easily slide out of the opening. For the left side, you have to detach the fuel sending unit to allow the float rod to line up against the side of the fuel pump. (white plastic base is clipped onto the metal housing) The opening is just large enough for the fuel pump to fit through with the float rod pressed against the fuel pump body.
The process is very straight forward and will take a couple of hours at a relaxed pace. Now that I’ve done it, I could probably do both sides in an hour. It doesn’t require a lift or any special tools.
Two things. 1) I don’t know if sending units are sold separately from the pumps anymore. My car had 199,000 miles on it so I decided to replace the fuel pump assemblies on both sides (pumps were original). 2) Inspect your purchases closely before tearing your car apart. The fuel sending unit I had for the left side had a small plastic piece broken rendering the unit inoperable. Fortunately I have more than one vehicle so I could leave the Vette apart for the 3 days it took to get a replacement.
I have had c5's do this running techron and shell gas cleaned up the sender.
On this car I just use the 1/2 mark as my time to fill the tank, I keep my odo set to trip A when I get up near 300 miles I know I better get fuel, usually about 10 gal fills it.
You can try shell fuel and techron if it cleans it all well and good if not there is a gas gauge removal in your future.
