Cole3 solved my HID lowbeam blues
Old Aug 14, 2015 | 08:07 PM
Stealth02's Avatar
Stealth02
Default Cole3 solved my HID lowbeam blues
Just wanted to put out a thanks to Cole3 for curing my lowbeam HID issue. I ordered his HID lowbeams with ballasts and his relay harness. The kit was top notch. Very straight forward and easy install. I also ordered a set of his HID fog lights. Best kit I've purchased so far and I've bought a few. Thanks Cole. Look forward to doing more business with you.
Old Aug 14, 2015 | 08:56 PM
Bleachcola's Avatar
Bleachcola
Do u have them in stock housings or projectors ?
Do u have a link to his hid fogs?
Old Aug 14, 2015 | 08:58 PM
Old Aug 14, 2015 | 09:38 PM
Stealth02's Avatar
Stealth02
I used them on ACA style housings with a projector lens for low beams. The relay harness really impressed me. Everything was plug and play. Was neatly routed with appropriate length leads and protective wire looms. It supplys power to the lowbeams directly from the battery through the relay. It also had built-in resistors to ensure each bulb recieves the same amount of power. Had an issue with the passenger side light not working. Ballast was not energizing due to low voltage. This harness corrected this problem.
Old Aug 15, 2015 | 12:54 AM
cole3's Avatar
cole3
Thank you for the compliments Rob!
BleachCola, the links are:
https://www.corvetteforum.com/forums...3697219&page=1
http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
To Cole3 solved my HID lowbeam blues
