ramps
Old Aug 16, 2015 | 01:43 PM
johnmike79's Avatar
johnmike79
Cruising
Default ramps
im looking to buy some ramps. Any suggestions or experiences? 00 coupe stock height.
Old Aug 16, 2015 | 04:55 PM
Race Ramps are excellent, but rather expensive. I use Rhino Ramps and they work for me.
Old Aug 16, 2015 | 06:33 PM
Odinson's Avatar
Odinson
I used the regular ramps from Wally World at stock height and they clear. Any lower though and it won't.
Old Aug 16, 2015 | 07:11 PM
REDHOTS's Avatar
REDHOTS
if you want to use the right tool for the job, spend the money for race ramps. Or like many others, just get by with whatever else kind of works, and struggle a little more. Good tools are priceless sometimes.
Old Aug 16, 2015 | 07:13 PM
Vanover's Avatar
Vanover
I got cheap ramp before I got my 03 .drove my pickup on them and smashed down,they work perfect for the car,no more truck on them.LOL
Old Aug 16, 2015 | 07:22 PM
Scn1998's Avatar
Scn1998
You can look up the info on the race ramps here in the forum. They look very nice but like the others have said they are pricey.
Old Aug 16, 2015 | 08:16 PM
Fred@ReverseLogic's Avatar
0Fred@ReverseLogic
Former Vendor
Race Ramps may be pricey, BUT, they hold their value very well. So the total cost of ownership is not that bad. The resale value of superstore auto ramps or homemade wooden ramps is close to zero. Used Race Ramps will typically sell for 50% to 75% of MSRP.
Here's a recent example:
https://www.corvetteforum.com/forums...ace-ramps.html
I sell new RLL-72-2 ramps for $306 when purchased with the "SAVE10" coupon code.
If you really want a low cost of ownership, buy used Race Ramps. When you go to sell them, chances are you will recoup your entire purchase price.
Old Aug 16, 2015 | 09:53 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I took these at a Bloomington Gold show:
Old Aug 16, 2015 | 10:03 PM
imlowr2's Avatar
imlowr2
race ramps are nice, but where do you store them when your not using them? I'm using the ramps from Harbor Freight. The plastic ones are a bit flimsy and feel insecure driving up them. The metal ones work if your car is stock height. Mines lowered so I use a 2X6 board and then use a floor jack. If I had the room, I'd install a hydraulic lift.
Old Aug 16, 2015 | 10:07 PM
imlowr2's Avatar
imlowr2
race ramps are nice, I'm using the ramps from Harbor Freight. The plastic ones are a bit flimsy and feel insecure driving up them. The metal ones work if your car is stock height. Mines lowered so I use a 2X6 board and then use a floor jack. I notice ebay has them for $200-300 range. If I had the room, I'd install a hydraulic lift.
Old Aug 16, 2015 | 10:33 PM
jdvann's Avatar
jdvann
These are a good DYI...
These have lights added.
http://corvettec3.ca/ramps.htm
Old Aug 17, 2015 | 09:31 AM
imlowr2's Avatar
imlowr2
Those are definitely nice for DYI, make sure you drive up the ramp perfectly straight with all four tires!
Old Aug 17, 2015 | 09:59 AM
dogboy's Avatar
dogboy
I have no room for race ramps. I would have bought if I did though. I got by using pep boys steel ramps. I jack the car way up until I can put the ramps under the tires & drop the car down on them. Forget about trying to drive up on them. The only issue is wide tires don't fit well in these ramps. The front ones (275/40-17's) can safely sit on them with a little overhang but the rears not (295/35-18's) Hell if I could get a set of used race ramps for under $300-- go for it!
Old Aug 17, 2015 | 03:52 PM
0Fred@ReverseLogic
Former Vendor
The platforms have straps so they are easy to hang on the wall. I store the inclines just below the garage door. This is pretty much a wasted space. The incline sections are light enough to lift overhead onto some Gladiator tote box brackets.
To ramps
