Rear Differential Lube
Old Aug 17, 2015 | 08:16 PM
Duhvet's Avatar
Duhvet
Default Rear Differential Lube
Is there a better brand of Differential lube to use in my 02 C5?
Old Aug 17, 2015 | 09:21 PM
bluestreak63's Avatar
bluestreak63
Better brand than what? This is one of those debatable questions, like which is the best oil to use. If you want today play it safe, visit your local Chevy dealer and tell them your year vette and they'll sell you some AC Delco diff lube.
Old Aug 17, 2015 | 09:22 PM
GREENKAR's Avatar
GREENKAR
I have a 2001 a 4 and my differential had a weep to it. So I changed out the lube using Valvoline gear lube. No more weep. Very
Old Aug 17, 2015 | 11:44 PM
garline14's Avatar
garline14
I went with Amsoil when I changed my diff fluid. It already contains the additive mixed in so I didnt add any. Once I was done i went to an empty parking lot, did some figure 8's, and all is good. I wasnt having any problems before I only changed the fluid so I know it has been done. But its the same as oil, you can get good results with different brands.
Old Aug 18, 2015 | 01:31 AM
Corvette#2's Avatar
Corvette#2
I used the AC Delco LS gear oil. Immediately did some tight figure 8's in a parking lot and tried to not go wide open throttle for 300 miles. (something about the additives needing to break in)
Old Aug 18, 2015 | 07:23 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by bluestreak63
Better brand than what? This is one of those debatable questions, like which is the best oil to use....
I do a complete fluid change on all of the family cars, every 3-4 years, depending on how much they've been driven. With my Corvette, it got Red Line fluids on the first change, and every one since then. But everyone has their favorites.
Old Aug 18, 2015 | 08:01 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
To Rear Differential Lube
