Serpentine belt
Old Aug 25, 2015 | 08:50 PM
3tt3v8P's Avatar
3tt3v8P
Default Serpentine belt
I was getting the car ready for a cruise this weekend and checking things over and noticed the serpentine belt was missing a small section of grooves. Ordered the belt and decided to check the idler and tensioner pulleys also. They were pretty loose so decided to change them also. Wow. Dint know how quiet the Moter could be. Wasn't too bad of a job. About an hour and all is good now. A little maintenance can really give you a great sense of confindance. Ready to cruise again.
Old Aug 25, 2015 | 09:15 PM
ttiros's Avatar
ttiros
How about the harmonic balancer, any wobble?
Old Aug 25, 2015 | 09:21 PM
Got to keep up on the maintenance - sure helps prevent unexpected surprises.
Old Aug 25, 2015 | 11:56 PM
1Willy1's Avatar
1Willy1
Im bringing mine in for the harmonic balancer in a week or two, which pulleys and tensioners should I have my mechanic replace while hes there?
All of them perhaps?
If so where did you buy yours? Which brand?
Old Aug 26, 2015 | 06:21 AM
ttiros's Avatar
ttiros
Mine goes in tomorrow for a new balancer. As I stated in an earlier post I am going with an ATI balancer. My Vette shop said I could go with a NEW stock bolt plus gasket. You might want to look at your A/C tensioner. On my 02 it had worked it's way out and was rubbing on the trans line. I had the tensioner replaced and re- routed the trans line. You also need a new serpentine belt obviously.
Old Aug 26, 2015 | 09:07 AM
3tt3v8P's Avatar
3tt3v8P
Looked to be running true. No wobble to it yet. 82000 miles
Old Aug 26, 2015 | 09:26 AM
3tt3v8P's Avatar
3tt3v8P
I picked them up at our NAPA store. Gates belts and gates pulleys. 104.00 for all. I would say if the pulleys still have a little resistance to them they should be good but I just wanted to replace them while I was in there. Good luck.
Old Aug 26, 2015 | 02:55 PM
traksta15's Avatar
traksta15
Need to replace mine. I have a squeek when it starts, when it's running and when I turn the car off.
To Serpentine belt
