Will these offsets work
Old Aug 25, 2015 | 10:28 PM
Sirk17's Avatar
Sirk17
Default Will these offsets work
Front 19x9 Wide 35mm
Rear 20x12 Wide 52mm
Wheel calc says it will be close does anyone run an offset like this?
Old Aug 26, 2015 | 05:17 PM
Sirk17's Avatar
Sirk17
bump any other thoughts?
Old Aug 26, 2015 | 05:23 PM
175rgr's Avatar
175rgr
They will work. But they will stick out pretty far, especially if you are running 325/345 size tire which is recommended on a 12 inch wide wheel
Say goodbye to your brake cooling ducts as well.
Below is how much a OEM c6 z06 wheel sticks out and they are 12inches wide at 59 offset which poke an extra 18mm. The wheels you posted will poke an extra 25mm. WAY to far IMO.
Old Aug 26, 2015 | 05:31 PM
Black 02's Avatar
Black 02
305s would be needed out back. Not sure up front as it'll be close, maybe a 235 or something.
I run 245s up front and 305s out back on my C6Z offsets and it works fine.
Old Aug 26, 2015 | 05:34 PM
Black 02's Avatar
Black 02
This picture shows why a slight stretch is required to pull off this look. With wide tires, it just looks like a 1980s setup.
Old Aug 26, 2015 | 05:36 PM
chassed's Avatar
chassed
ive got 18x13 wide wheels with 335/30/18 tires.... with 8.50 BS...i still have my rear break ducts
Old Aug 26, 2015 | 05:41 PM
Black 02's Avatar
Black 02
Brake ducts will be fine. You are moving the wheel and tire package towards the outside of the fender. If you were going wider and keeping them inside the fender then the ducts would be a problem.
Old Aug 27, 2015 | 01:42 PM
175rgr's Avatar
175rgr
Correct, I was thinking about the OEM c6 z06 wheels. I ran them on my old C5 Z06 with 325's and had to remove the ducts.
Old Aug 27, 2015 | 02:18 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
it'll look just like having c6 z06 wheels on the car.
C6 z06 wheels are 9.5 wide with 40mm front and rear are 12 wide with 59mm. I use a 4mm spacer to keep from rubbing inside. That puts me at 55mm.
https://www.corvetteforum.com/forums...only-pics.html
Old Aug 28, 2015 | 12:18 AM
Sirk17's Avatar
Sirk17
So would these be a great fit for a C6 Z06 then you think?
Old Aug 28, 2015 | 09:44 PM
Sirk17's Avatar
Sirk17
They would have worked with a c5 with L5 wide fenders. Anyone in orlando looking for a small project and a steal on some sick HRE wheels keep an eye in here.
Old Aug 29, 2015 | 07:25 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
I have stock fenders. My point was it would look pratically just like my car.
Old Aug 29, 2015 | 11:51 AM
Sirk17's Avatar
Sirk17
I dont think the guy has the correct offsets in the rear. They stuck way out 2.5 inches or so, looked like a dump truck, the fronts were good but wouldn't clear C6 z06 brakes. For a C5 with wide fenders they would have been a great fit. Great fit....here is the craigslist link if anyone wants to give it a shot.
http://orlando.craigslist.org/pts/5166505667.html
He had the bore machined to Corvette/ BMW diameter. The rears would require a little deeper bore which he said he would have done or like 2.5mm to 5mm spacer for the added room needed to sit on the hub 100%
I think its a good deal on the wheels after a little cleaning and some sanding they would be 95% if i had wide fenders I would have got them no doubt.
Just a project im not ready for as I found out my MT ET streets are toast after bad camber wear to the threads on the left side.
To Will these offsets work
