I've got a black wing cold air intake ,I need to clean in but icant find the recharge kit anywhere .were do I find it .went on there site,didn't see kit to recharge.
There are a lot of kits available as posted above, or you can do it yourself.
To clean, use Simple Green and water.
To re-oil, use a mixture of mineral oil and isopropyl alcohol. Use just enough alcohol to allow the mixture to be sprayed. The alcohol will evaporate leaving the recharged filter.
Spray the recharge sparingly. It doesn't take much to recharge the filter, and too much can cause issues with mass air flow sensors.
