rear diff fluid leak
Old Aug 29, 2015 | 04:30 PM
yoymon's Avatar
yoymon
Default rear diff fluid leak
just came home from ride in vet and smelled rear diff oil, is leaking so bad its getting thrown on to exaust, assume its the seal where axle goes into rear end since there is that much oil getting out, had seepage from diff cover but now its wet....not sure if I can do this job especially on garage floor, some of the old threads links aren't good anymore, tell me whatever you can, need help, thanks...99 a4 by the way
Old Aug 29, 2015 | 04:49 PM
yoymon's Avatar
yoymon
Originally Posted by 8VETTE7
Perhaps not a seal leak. Read here:
http://forums.corvetteforum.com/c5-t...d-removal.html
great thanks I will go check this out right now, I hope that's all it is...ill update asap!!!
Old Aug 29, 2015 | 05:16 PM
Lee DeRaud's Avatar
Lee DeRaud
If it's getting on the exhaust, it's misting out somewhere (vent is the obvious suspect), not the normal axle seal seepage.
Old Aug 29, 2015 | 05:30 PM
yoymon's Avatar
yoymon
looks like it could be the vent...the "cap" moves around very easily not up and down but spins and wiggles like its just sitting there, but can get a grip on it to pull it out or to pull cap off and remove spring etc..
Old Aug 29, 2015 | 06:00 PM
yoymon's Avatar
yoymon
just got cap off rubber gasket was held over opening by huge suck of vaccume pulled it off big woosh..good or bad not sure but gonna put a hose on like suggested in thread, that spring is so flimsy I cant see how it did anything at all
Old Aug 29, 2015 | 08:23 PM
yoymon's Avatar
yoymon
had a heck of a time getting hose clamped on solid...decided to cut off a 2 inch piece was much easier to get into place and get clamped tight, now I have to go to store 2moro and buy an elbow and attach 6 inches or so if hose to that, will get a can of brake clean and clean everything up before test drive, ill check fluid level to since I was on about an hour ride in case its low, thanks for the help guys, hope it does the trick
Old Aug 30, 2015 | 12:17 AM
Hope that fixed it. This was a very informative thread.
Old Aug 30, 2015 | 11:13 AM
yoymon's Avatar
yoymon
just got back from first test drive, just a few miles in case rear axle seal was still the problem and its bone dry, need to go on longer test drive and get it hot but assume if it was the axle seal it would have leaked immediately, great advice guys
Old Aug 30, 2015 | 01:59 PM
GCG's Avatar
GCG
Good to hear that!
Were you able to check the fluid level? Was it fine, or you had to top it off?
To rear diff fluid leak
