[Z06] Car rattles when shut off
Old Aug 22, 2002 | 03:17 PM
HIRPOWERZO6's Avatar
HIRPOWERZO6
Default Car rattles when shut off
Sence the car has been pick up the noise come's only when you shut it off ,it seems to be getting louder as the miles are put on ,the noise sounds like lose bolts .... I have put the car on the lift to find it ,( NOT READY to take to the dealer yet HAVE HAD BAD EXPERIENCES WITH THE DEALERS AROUND HERE,IF I CAN DO IT BY FIXING IT AND SAVE A HASSLE I WILL )and try to duplicate it and try find it my self but no luck yet ,also thought maybe the exhaust system somewhere because on the lift the car has different pressures applied so it stiffen the car different as it sits on the ground ??
It dosent make the noise when running
has anyone have the same experience with there Z06 at all?,
thanks
Gary :chevy :D
Old Aug 22, 2002 | 03:33 PM
ZippoMan's Avatar
ZippoMan
Default Re: Car rattles when shut off (HIRPOWERZO6)
Do you have the clutch pushed in while shutting off? Does it make the noise if the clutch is in and out (neutral)?
Old Aug 22, 2002 | 03:42 PM
HIRPOWERZO6
Default Re: Car rattles when shut off (ZippoMan)
yes your right the car is in neutral and the clutch is out while I am shutting the car off.
Gary
Old Aug 22, 2002 | 04:01 PM
jerryv's Avatar
jerryv
It's normal. Don't worry about it. They all do it. It's mentioned in the video.
Old Aug 22, 2002 | 05:04 PM
Black2001Z06's Avatar
Black2001Z06
Default Re: Car rattles when shut off (Jerry Velders)
Yes, it does rattle. Hold the clutch in. Noise is part of the torque tube design with the rear mounted transaxle.
Old Aug 22, 2002 | 05:22 PM
Bertrand's Avatar
Bertrand
Is the engine still running when the noise happens or is it after you turn it off?
Old Aug 22, 2002 | 05:23 PM
HIRPOWERZO6
Default Re: Car rattles when shut off (Black2001Z06)
Thanks everyone ,I was thinking somehow something was going to fall off,I will watch the video know ,I guest I am at it backwards
Thanks for all the replys
Gary :cheers:
To Car rattles when shut off
