Do I need the LMC5?
Old Sep 6, 2015 | 09:33 PM
Fick's Avatar
Fick
Default Do I need the LMC5?
I recently purchased an 02 vert M6. The steering wheel will not lock up with or without the key in the ignition. I have a receipt showing that a new ignition control module was installed by the dealer in 09 due to the column locking up. How do I know if the LMC5 is needed or of it has already been done? As I said the column will not lock now at all.
Old Sep 6, 2015 | 09:35 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
if it doesn't lock at all I suspect you have more than the GM "fix" done...I doubt GM would fix the car and disable the lock
Old Sep 6, 2015 | 09:42 PM
73Corvette's Avatar
73Corvette
You can pull the partition in the passenger floor well, where the BCM and a fuse box is... IF the LMC5 is installed you can inspect the BCM and/or see the LMC5 module it looks like this....
Old Sep 6, 2015 | 09:44 PM
pewter99's Avatar
pewter99
if you have a CLB installed it will be under the drivers knee bolster...small black box
Old Sep 6, 2015 | 10:13 PM
73Corvette's Avatar
73Corvette
Also agree that if the Column DOES NOT lock without the Key in the Ignition then some sort of recall work was done or someone put in a CLB... that being said you still need to do the LMC5 IMHO...
Old Sep 6, 2015 | 10:35 PM
scarecrowkc5's Avatar
scarecrowkc5
My 2002 base does not lock either.
I need to check and see what they did.
I pulled the floor and don't see the LMC5 module.
Old Sep 6, 2015 | 10:49 PM
73Corvette's Avatar
73Corvette
Is your car a 6 speed?
Old Sep 6, 2015 | 10:50 PM
scarecrowkc5
Sorry, it's an auto.
Old Sep 6, 2015 | 10:56 PM
73Corvette's Avatar
73Corvette
No problem... NO need for the LMC5 module and you can sleep better tonight
Old Sep 6, 2015 | 11:20 PM
scarecrowkc5
Thank you sir.
Old Sep 6, 2015 | 11:58 PM
Fick's Avatar
Fick
Thanks everyone, I ordered the part, better safe than sorry.
To Do I need the LMC5?
