Manual Driving Tips
Old Sep 9, 2015 | 09:40 PM
It'sOver9000!!'s Avatar
It'sOver9000!!
Originally Posted by MGMTF
Nice, what do you do at low speeds to prevent the car from lurching when coming off the gas? (#1 in original post)
In first I just disengage the clutch to prevent lurching... if I need to let the car coast for anything longer than a couple seconds in that situation I'll just put her in neutral and let her roll along via momentum.
Old Sep 10, 2015 | 10:38 AM
Lazarus Long's Avatar
Lazarus Long
My corvette is my first manual car, so my experience is the same as yours. I still am not comfortable with quick launches, and haven't figured out the correct rpms for rev matching on downshifts.
Anyway, I think some of the lurching may be due to you be unaccustomed to manuals vs autos. In an auto, when coasting at low speed the torque converter unlocks and freewheels- there is slippage between the wheels and engine.
With the manual, there is no slippage unless you depress the clutch pedal. When coasting, you are engine braking and the effect is more pronounced in 1st gear.
When I approach red stop lights, I shift into neutral and coast to the light. I've read that it is hard on the throw out bearing to sit idling with your foot on the clutch.
Old Sep 10, 2015 | 10:57 AM
73Corvette's Avatar
73Corvette
Nice explanation
Old Sep 10, 2015 | 11:20 AM
Macleod52's Avatar
Macleod52
I still have trouble with first gear even though I've driven manual for years. I think my problems is that in order to get a smooth take off I feel like I'm slipping the clutch too much and too worried about wear and tear. I don't have problems with any other gears and even WOT shifts are near perfect.
Old Sep 10, 2015 | 11:24 AM
73Corvette's Avatar
73Corvette
I had a hard time too until Chuck did the throttle response when he tuned the car... it just made a huge difference. It drives like a drive by cable car now not a drive by wire...
Old Sep 10, 2015 | 11:28 AM
MGMTF's Avatar
MGMTF
Is the TAC module able to be tuned via the PCM?
Old Sep 10, 2015 | 11:32 AM
73Corvette's Avatar
73Corvette
Want to know how bad your existing throttle response is??? When you press the
gas pedal in your CORVETTE 50% or HALF WAY DOWN you're actually getting less than 15% of the throttle blade open. Worse
yet, when your taking it easy and only stepping on the throttle 1/4 or we'll say 25% down, you're actually not getting
much more than 3% of the engine's throttle blade open. This why ELECTRONIC THROTTLE cars don't feel like they have much
Copied and pasted from the Chuck CoW booster ad...
Old Sep 10, 2015 | 11:35 AM
73Corvette's Avatar
73Corvette
Not sure how or exactly what it does... this is what I do know.
It took SEVERAL years to crack the code to manipulate the C6 accelerator issues... some of that has trickled down to the C5 and he can significantly change the way your cars throttle response works... when he did our tune it's one of the FIRST things he did... I almost would have been satisfied if he had stopped there...it was amazingly different in a GOOD way! I'm glad we finished the tune though.... holy crap *****!
Old Sep 10, 2015 | 12:18 PM
Lazarus Long
That explains why it feels like there isn't much there until you really put the foot down. Electronic throttle does seem like a stupid idea. I suppose it is yet another measure to beat the gas guzzler tax.
Old Sep 10, 2015 | 12:23 PM
JR-01's Avatar
JR-01
Not to mention:
Software or electronic failures within the ETC have been suspected by some to be responsible for alleged incidents of unintended acceleration.
There has been deaths due to electronic throttles.
Old Sep 11, 2015 | 03:32 AM
beboggled's Avatar
beboggled
I have a cammed manual car as well. My lurching doesn't seem as prominent as yours but I totally understand how it limits your ability in parking lots. The minimum speed I can drive is ~8-9 mph with the clutch in due to an idle at 1K and some lurching.
Personally, I use momentum a lot in my manual driving and just coast in neutral, especially at parking lot speeds. The car rolls a lot farther than you think it would in neutral. Before I even get to the parking space I put it in neutral and let go of the clutch, (or keep it in 1st and hold the clutch all the way in) so I can focus more on accurate parking/positioning in the space/brake modulation. Also, if I'm in very slow traffic, it makes sense to give at bit more room in front of me than most others, put it in first and get to 15 mph or so and then just put it in neutral and coast between the pulses of traffic. Otherwise you will constantly be engaging/disengaging the clutch and slipping it unnecessarily which puts extra wear and is tiring. The clutch is not the easiest to change; trust me I did it myself.
Old Sep 11, 2015 | 03:41 AM
MGMTF's Avatar
MGMTF
Thanks for the tips
A slightly separate but related question for you guys, how many of you double clutch when down shifting? As far a I know it isn't necessary with a synchronized trans but was just curious if anyone does it? Currently I just choose the gear that appropriate for the speed I am going and where I want the motor in the powerband and rev match while releasing the clutch. That is fine to go from say 6th to 4th or from 5th to 3rd correct? The only reason I ask is because with the rear mounted trans of the C5 the synchros have more work to do changing the speed of the entire driveline up to the motor.
Old Sep 11, 2015 | 07:04 AM
  #33
VettesGoneWild's Avatar
VettesGoneWild
Originally Posted by dadaroo
OP, one thing you need to do is when going from a stop and leaving in First you need to add RPMs to get up to a reasonable speed to fully engage the clutch sooner without stalling the car. If you are riding/slipping the clutch all the way through first and only let it become fully engaged about the time for Second you are putting unnecessary wear on it. If someone is in front of you let them go and just delay your motion.
Replacing a clutch on these cars is a significant effort due to the torque tube design. No just dropping the driveshaft and removing the bell housing.
Everything else in your Post 1 seems fine.
Mr. Sam
At what RPMs do you reach before letting out the clutch in first? I have been letting out the clutch *as* I increase RPMs and feel as though I am riding the clutch, maybe bogging the engine too. It feels like if I increase the RPMs too much before clutch release I'm going to lurch or take off too fast. Once rolling I don't baby it though. I am comfortable with the other gears. Part of my problem may be shifting as I did in my 69 Chevelle SS396 I owned many years ago...old habits I guess. I know, I need to practice. Have driven the Vette about 7K miles since purchase last year.
Old Sep 11, 2015 | 08:12 AM
  #34
dadaroo's Avatar
dadaroo
I have no idea what RPMs I leave at but I can check the next time I go for a drive. Yes, you need to raise the RPMs some and then start letting the clutch engage to start moving. Just practice so it is a shortened time and smooth.
Old Sep 11, 2015 | 09:02 AM
  #35
Macleod52's Avatar
Macleod52
Thanks for the tips
There is no need to double clutch on the C5 or any modern car (AFAIK). I just blip the throttle to get the RPMs up to match the gear I'm shifting to.
Old Sep 11, 2015 | 11:58 AM
  #36
MGMTF's Avatar
MGMTF
That's what I thought, thanks.
Old Sep 11, 2015 | 02:03 PM
  #37
funnyguyMI's Avatar
funnyguyMI
Regarding #3 - chirping 2nd is one of my favorite parts of driving the car!
To Manual Driving Tips
Old Sep 11, 2015 | 06:27 PM
  #38
REDHOTS's Avatar
REDHOTS
Smooth shifting, is all about rev matching. Not easy on a C5, but a few years ago, I had a 1930 Model A with a 3 speed, no synchros. Although, I learned long before that, other than taking off in 1st, if done right, matching revs, and load you can shift up, and down without even using the clutch. Better with a clutch though. It takes practice to shift smooth. I can shift a manual much smoother than most automatics. I have driven more than one car back home with broken clutch linkage, by starting the car in first gear with the starter, and rev matching through the gears. You should be able to shift your car seamlessly, up, or down, if done right. Being able to operate all 3 pedals with 2 feet is a very important technique to learn!
Old Sep 11, 2015 | 10:44 PM
  #39
AndyDove's Avatar
AndyDove
Default Driving the M6
Like you I'm getting used to driving a manual again. I came to the US from UK 10yrs ago, and before I came I only drove manual (first was a Mini 1275GT, last was Audi A4 - all manual). My 99 vette (bought from Buds a few weeks back) feels surprising natural to drive, but it does take more thought than an auto (I've also got a 2015 Durango R/T).
Modern cars have drive-by-wire for shift quality improvements, but the old school vette requires a delicate touch if you're just cruising. I find that to get a smooth pull away without the jerk, just give the clutch a tiny amount more pressure when you feel the biting point approaching jerk and give a bit more power at the same time. That smooths it out nicely.
Regarding double-declutching, I do it a lot, especially if down shifting to over take in a 'spirited manner'. It makes for a much smoother shift! Mind you, my old mini (no 2nd gear synchromesh) meant that's how I rolled The Corvette has a synchromesh of course - but it's still a lot nicer (and better for the transmission) to D-DC.
Old Sep 11, 2015 | 10:45 PM
  #40
AndyDove's Avatar
AndyDove
Default Joke...
Did you hear about the Irishman who failed his driving test?
He opened the door to let the clutch out!
