[Z06] HELP/MAFT/ car won't start
Old Aug 22, 2002 | 08:06 PM
edv2122's Avatar
edv2122
Default HELP/MAFT/ car won't start
I installed the MAFT in my Z. Hooked up all colored wires to were they were sapose to go. Checked and re checked. Went to start the car and it started for a second then shut off with check engine light. :confused: Anybody have any trouble with the install or have any ideas what is wrong with my car?
Old Aug 22, 2002 | 10:16 PM
Z11409's Avatar
Z11409
Default Re: HELP/MAFT/ car won't start (edv2122)
Check the dip switches--all should be in the off position--set the base and wot switches to Zero.If it still will not start--go back to square one and remove the maft connections and re-attach the orginal wires.
Old Aug 22, 2002 | 11:23 PM
edv2122's Avatar
edv2122
Default Re: HELP/MAFT/ car won't start (Z11409)
I got it fixed! I took everything apart then re installed it. Worked this time. I must have screwed something up the first time around. base at 5% wot 0 :D
To HELP/MAFT/ car won't start
