Help with C5 turn signals
Old Sep 18, 2015 | 05:51 PM
babysitr's Avatar
babysitr
6th Gear
Default Help with C5 turn signals
Need help diagnosing rapid flash on LH signal lamps..Everything works fine using emergency flashers. When using left signal, lamps work,but, flash much faster than rh side...car has LED rear lights, so I switched them side for side, and the problem stayed on the left side..also replaced left front bulb, just for grins,but they still flash too fast....they work,but looks silly.....any ideas???? thanks..
Old Sep 18, 2015 | 08:48 PM
BSenzina's Avatar
BSenzina
Flasher maybe???
Old Sep 18, 2015 | 09:27 PM
katrinacop's Avatar
katrinacop
Check out this link:
http://shop.jwmotoring.com/C5-LED-Hy...ashHarness.htm
Its my understanding that whenever you add LEDs to the turn signals you need to install a "LED Hyperflash Harness". I converted to LED and installed LED lights front and rear of my C5 (halo option) and installed this (above link) harness and that took care of the hyper flash.
I'm not sure if you can find a better price somewhere else but I haven't had any problems with my JWM products and its been 2 or 3 years. Hope that helps
Old Sep 19, 2015 | 09:34 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Fix your flasher problem AND get LEDs for the front as well.
http://shop.radioflyerinnovations.co...rvette-091.htm
To Help with C5 turn signals
