Steering wheel lock.
Old Sep 19, 2015 | 07:34 AM
black match box's Avatar
black match box
Default Steering wheel lock.
Hi Guys: the question is when I bought the car I was told that the steering wheel lock recall was done, I belive I have the paper showing that but cant find it. If this work was done when I turn off the car the wheel should not lock correct? well it dose. can a dealer tell me if it was done or not done. I have the LCM5, but if it was not done do I need the unlocker allso. Thanks Gino. this is a 2000 6speed. the wheel is not locked yet.
Old Sep 19, 2015 | 08:02 AM
dadaroo's Avatar
dadaroo
The factory recall never fixed the problem unless they did the physical modification on the pre 2001 automatic cars.
If your column locks and unlocks normally you don't need the unlocker.
I consider the LMC5 to be the best Column Lock problem permanent fix out there. It also does not require you to “undo” any previous CL attempts to resolve this issue. Their eBay ads have a good video that shows the install at the BCM. It does not cover everything in the written instructions. So, read the instructions and also here is some extra info. In some cases, the BCM timing is off just enough to cause some issues. They make several versions and they can swap out/provide one of these if you have any issues. Their customer support is as good as it gets.
Not uncommon for people to "put the column in a pre-lock condition" and not know it and then start with the install. In other words, they started with the column lock “energized’ even if it was not actually locked yet. If not actually locked yet, it will be as soon as you turn the steering wheel after the LMC5 install. It will then remain in the locked condition until you cause the motor to unlock. It will then remain in the unlocked condition since the motor is then unpowered with the circuits disconnected.
Here is one way to prevent that if your column locks and unlocks normally:
If the CL is functioning normally you don't not need the Unlocker, merely turn the ignition ON, pull fuse #23 in the I/P fuse box, turn ignition OFF, turn the steering wheel (left and right) and verify it is unlocked. Next, disconnect the negative battery terminal, re-insert fuse #23 and continue with the install.
Also the 1999 and later C5's have a column lock relay that can be unplugged or else it will be powered and could fail and drain the battery. The LMC5 written guidance provides this info. This relay is above the BCM.
They also have a great install video in their eBay ads you need to watch.
Compliance Parts website: http://complianceparts.com/index.html
Mr. Sam
