Tire Sensor or Wheel Sensor?
Old Sep 19, 2015 | 02:55 PM
Mrmoose's Avatar
Mrmoose
Default Tire Sensor or Wheel Sensor?
Morning all
For the past year, my left rear tire show as being flat when I first start driving. It eventually reads properly and all is well. However, there have been a couple of times when after driving a long distance, stopping for about an hour then driving again, that sensor has taken a good half hour before it kicks in. At that point then the TPMS has assumed that it has lost contact. Does this sound like the tire sensor? or wheel sensor?
It only happens on that tire
Old Sep 19, 2015 | 03:24 PM
Bill Vett's Avatar
Bill Vett
What year is your car, I checked your profile for a year but is not filled out.
Old Sep 19, 2015 | 03:56 PM
CQRT's Avatar
CQRT
Sounds like a weak battery in the sensor? Try reprogramming first . . .
Old Sep 19, 2015 | 05:53 PM
Phanni's Avatar
Phanni
Weak battery in sensor.
Old Sep 19, 2015 | 08:30 PM
Originally Posted by 8VETTE7
Sounds to me like the Tire Pressure Monitor in the left rear tire is bad.
Not much else it could be.
Old Sep 19, 2015 | 08:58 PM
65GGvert's Avatar
65GGvert
Just for grins, how much air is in that tire, measured with a manual gauge?
Old Sep 20, 2015 | 09:38 AM
Mrmoose's Avatar
Mrmoose
thanks all
its a 98 corvette. 31 PSI is what is normally in the tire
Old Sep 20, 2015 | 11:22 AM
Bill Vett's Avatar
Bill Vett
Originally Posted by Mrmoose
thanks all
If they are the original sensors they are well past their life span of 10 years. They will need to be replaced. Because they are generation 1 sensors the cost is about $70.'s each vs. under $50's for generation 2. If it were me I'd replace them all at the same time and not have the next one go bad a month from now, or if you intend to keep the car for over 10 years I'd switch to the gen. 2 system for under $500.'s.
Old Sep 20, 2015 | 11:32 AM
Lee DeRaud's Avatar
Lee DeRaud
You could move the left rear tire to the right rear tire and then retrain the TPM's (see video below) and if the problem moves to the right rear tire you know 100% the TPM in that tire is the issue.
That'll work, although if the sensor is that marginal, it probably won't get through the training cycle.
(And don't forget to put the wheels back on the correct side when you're done.)
Old Sep 20, 2015 | 12:11 PM
Lee DeRaud's Avatar
Lee DeRaud
That will prove the point as well......
Absolutely.
Regarding the wisdom of replacing all four at once: I'm not sure about the older system, but the newer one doesn't like having sensors of different signal strengths. If you drop a new one into the mix, old ones that worked before may fail to retrain. DAMHIKT
Old Sep 20, 2015 | 12:18 PM
Lee DeRaud's Avatar
Lee DeRaud
Upon further review: the system doesn't know where the tire is mounted, just what order they were trained in. Just retrain the rears in reverse order, no need to move any wheels.
Old Sep 20, 2015 | 12:55 PM
Lee DeRaud's Avatar
Lee DeRaud
You cannot train just 2 sensors. You must train 4 sensors or the newly trained sensors will not be remembered. You can, however, train the sensors out of order. Correct order is LF, RF, RR and LR.
That's what I said.
To Tire Sensor or Wheel Sensor?
