C5 xm radio install
In the passenger side footwell, remove the small carpeted toe-kick panel and that will reveal a connector with a pair of hot wires and a ground wire. The orange wire is constant 12v and the yellow wire is 12v ignition switched. The black wire is ground. Either one of the power leads will handle a 10A load. Fuse 11 in the instrument panel fuse box is for the accessory power harness.
Received 19,305 Likes
'20-'21-'22-'23-'24
Good luck with the install.
USA2170 (09-27-2015)
Received 1,216 Likes
On 04’s, fuse 11 (20 amp) in the passenger fuse panel is an ignition ON feed for Accessory Power. I used this fuse for adding power to a dash cam and per comments to me from Mr. Sam, it does NOT provide power to anything else. Also, fuse number 22 noted as Body Control Module – Ignition 3 in the owner’s manual is open and does not power anything.
Hope this helps.
Hope this helps.
In the foot well tap fuse #11. It is switched and will be hot only when the ignition is on and in acc. I did it this way when I changed mt mirror to an Onstar Mirror.
C5 XM radio Install
Thanks everyone for all the info on my install. Here are some pix of the finished XM/Sirius radio in my C5.. After putting everything back together.....Guess what Unable to open FUEL DOOR and REAR HATCH. I have no idea whats up....anyone have any idea...
Hope this helps.
Hope this helps.
Former Vendor
2004 connect under the steering column
Thanks for the link, it helped. That install must have been another year. He was talking about fuse # 26 (F/TNKDR) on his vehicle. I found that on my 04 that fuse #32 was for (F/TNKDR). Once that was replaced, fuel door release worked and rear hatch opened. Again thanks so much.
hi nice work, any problem with water getting in ( driving or washing) mine is a daily driver. Thanks
