Need bigger injectors for ls6
Old Oct 2, 2015 | 10:53 PM
c5z06.O's Avatar
c5z06.O
Default Need bigger injectors for ls6
I need some guidance in purchasing bigger injectors than the stock ones.
My tuner said I would be ok at the max level I'm in. Somewhere in the 90 percent area. Dont remember.
My later ventures would just add the fast and the ls2 tb later.
I just want to start with the injectors.
Not ever going to add a blower. Got over that one. If anything I will end up changing the whole top end.
Goals would be ideal but just want to upgrade what I think I should first.
Car does die out sometimes after wot
When I come to a stop.
Old Oct 3, 2015 | 05:06 AM
Ferg03 Z06's Avatar
Ferg03 Z06
Its obvious your car is modified. I recommend the FAST 42lbers. That should be more than enough injector for even a large cam with heads and a 102...I have them and I love them in my car
Old Oct 3, 2015 | 11:07 AM
c5z06.O's Avatar
c5z06.O
Default 60lb Siemens deka
Found some of these online. Cant tell what's real and what's fake.
Old Oct 3, 2015 | 05:00 PM
nullpointer's Avatar
nullpointer
Talk to your tuner and find out what injector data he has access to. Injectors are worthless without the correct data. Some injectors (the good ones) come with all the data you need, like IDs.
Stay away from Lucas brand injectors, impossible to get good solid data.
Old Oct 3, 2015 | 05:51 PM
c5z06.O's Avatar
c5z06.O
Default Thanks for the replies
I asked my tuner and he suggested the Siemens Deka. Also said that the 42lbs would be perfect.
Now to look for some Siemens Deka 42lbs that I don't kbow nothing about.
Thanks again
Old Oct 3, 2015 | 05:56 PM
nullpointer
https://secure.fuelinjectorconnectio...ance-p302.html
Their Ebay store has the same price but free shipping
Old Oct 3, 2015 | 06:31 PM
c5z06.O's Avatar
c5z06.O
Default thank you
I did go to that Web site. They have two of them. One of them redirects and the other one said secure before the address.
Thanks though. I'm buying them today.
To Need bigger injectors for ls6
