I am a new-be and would like to ask a question. Under the a/c & heat controls there is a rectangular compartment. The door seems broken and will not close properly. What do I need to do to fix it?
Originally Posted by RockyL32
Sounds like where the ash tray and cigarette lighter was
Originally Posted by bartsky
Most likely the spring came off, or broke.
If the spring came off, you might be able to find a replacement at a hardware store or try calling Marc at Vettenuts and see if he has one laying around.
Need clarification. Are you referring to the large door under the AC control that covers the lighter and ash tray or the smaller door under the larger door which is the ash tray? If it is the latter, the ash tray door automatically springs open when you open the larger door.
