Competitive driving mode
Old Nov 2, 2018 | 06:55 PM
Crosis's Avatar
Crosis
Old Nov 2, 2018 | 09:03 PM
Dark Sarcasm's Avatar
Dark Sarcasm
I've used comp mode while autocrossing and spun out. Looked at the DIC and it said "active handling warming up" This happened more than once so now I just turn it off completely. I want to know how the car reacts under my control without the help of a computer, especially when the computer needs to warm up first. Apparently for active handling to "warm up" there needs to be a certain distance (100ft?) driven in a straight line. Don't have that luxury at my usual autoX venue. The grid is less than 100feet then turns for the start line.
I keep both on while driving on the street.
Old Nov 2, 2018 | 10:34 PM
z06801's Avatar
z06801
You will notice it most while on the track, you'll feel a tug at the rear wheels, it's much faster running everything off. The abs is really good imo.
Old Nov 3, 2018 | 04:28 PM
DVUSz06's Avatar
DVUSz06
Originally Posted by 73Corvette
The competitive mode makes your hearing super sensitive... car will sound louder and faster. It will also make your nut sack swell a bit and send testosterone coursing through your veins... you will likely have some dizziness and possibly have delusional tendency to think your a race car driver...you also may find feelings of aggression, wanting to speed away at stoplights because some little old lady in her 80's station wagon looked at you. You also could suffer from a moderate form of Psychosis, sitting in your garage making vrrrooommm sounds while jerking the steering wheel back and forth pretending to be at Darlington Speedway doing battle with NASCAR greats from the past...
Other than that it doesn't really do much...
love that 👍👍it's exactly how mine works also
Old Nov 4, 2018 | 10:54 AM
UM Rebel's Avatar
UM Rebel
Originally Posted by dbgoodwin
All it does is turn of traction control but leave active handling on. Basically allows spinning of the tires and mild slides but prevents you from getting really sideways or spinning out.
Don't believe for a second that Active Handling will keep you from getting sideways or spinning out. I believe it's stated , Active Handling is designed to work with existing traction to assist the driver - but it can not overcome the laws of physics.
