Hooking up tender
Old Oct 10, 2015 | 12:33 PM
VettesGoneWild's Avatar
VettesGoneWild
Originally Posted by jptgs1
Going on 3rd winter with the cig lighter adapter.
I use the cig lighter adaptor also. Works just as well as any other hookup method electrically speaking and is quick and easy connect/disconnect.
Old Oct 10, 2015 | 03:51 PM
rrwirsi's Avatar
rrwirsi
No storage with mine but I am not in the high level snow country. Every week during the winter (its coming, ugh!), I drive the vert for at least 25 miles. Sometimes with the top down in 30 degree weather. Maybe more miles depending on the weather and salt on the roads. This keeps my battery and fluids happy.
Old Oct 10, 2015 | 05:14 PM
Cliff8928's Avatar
Cliff8928
Originally Posted by JR-01
Do you disconnect it? A dead battery can freeze and possibly crack the case.
Yes, I disconnect it. Primarily because it's parked at a vacation home where nobody is at most of the time. The building is insulated fairly well though. Every time I reconnect it there is no evident voltage loss (it doesn't crank slow, etc.).
Originally Posted by knewblewkorvette
4 months I let my 02 sit for 4 weeks and she'll not start
Mine has definitely sat for a month or so without being started in the summer time (like during my clutch job last year) no troubles there. I would be concerned if mine died that quickly. The STS on the other hand has the keyless access system (like the C6) and it's well known that those only last about a month or so without being driven before they go dead.
