If you order Chinese, you can get "insanely" cheap. Quick example. LR44 batteries (the small ones you stack 3 or 4 in small flashlights) here in the US are anywhere from roughly $1 to $2 each but I bought a pack of 50 from China for $5 shipped to my house (it was $2.99 + shipping). 100 pack is $8.50 and so on. Might just be worth a shot... Wonder how long they'll last though. I kinda have a feeling that the Chinese batteries are a smidge inferior.
True...they are $53 shipped right now. Ordered the set & just like Mr. 23, I will let yall know how well they work/last.
Might be worth it for non-mission-critical applications. I've got any number of digital calipers, thermometer, etc that use that size and are too stupid to shut themselves off after a decent interval.
I installed those Titan after market sensors last year when I got new wheels and tires. Worked fine for a month and then failed, that's right ALL 4 of them. Tried everything to get them to work, magnet trick for sure. Would not train. Called Titan and they could not get them to work either. Got the correct GM ones and have not had a problem since. Luckily Titan gave me my money back.
Some of you have had good luck with these but others have not (search the forums).
So received and installed the set for $53, so far so good! Took them to discount tire to install them and then set them myself with a high powered magnet. It's been close to a month now.
