Wheel install attempt 1 = FAIL
Old Oct 10, 2015 | 07:29 PM
GTJim's Avatar
GTJim
Default Wheel install attempt 1 = FAIL
So today I had planned to install my new TSW Interlagos wheels and tires. Had my jacking puck, lug nut socket, and floor jack all ready to go. Loosened the lugs on the wheels on the one side of the car and went to jack the car up. Jack no fit under car, WTF!!!!
Of all the stupid idiotic things I forgot to check to see if the jack would work!!! My car is lowered all the way on the stock bolts and has low profile tires, has about 3.5 inches clearance to fit a jack under the car. Lowest jacking height for my Sears Craftsman jack is 5 inches, 4.5 if you remove the cup. Not gonna work.
Bought a new jack today with 3.5 lowest jacking height. Lowest profile jack I could find locally on short notice. Gonna be close but I think it will work. Tomorrow we try again.
Old Oct 10, 2015 | 07:37 PM
Black 03 Z06's Avatar
Black 03 Z06
Run the car up on some 2" x 6" framing lumber. Gets it up high enough to get any low profile jack under the car.
Good luck. Work safety.
Old Oct 10, 2015 | 07:39 PM
Vanover's Avatar
Vanover
Drive it up on some 2x4s,and take the new jack back.
Old Oct 10, 2015 | 07:41 PM
GTJim's Avatar
GTJim
That's why I stopped and bought a new jack. Figured its better to have the proper tools than try and rig it.
zdeckich's Avatar
zdeckich
2017 Corvette of Year Finalist
2016 C5 of the Year
2x4 works perfect for me as well.
Old Oct 10, 2015 | 07:44 PM
MikeG37's Avatar
MikeG37
I'm lowered all the way on stock bolts and have 2 1' pieces of 2"×12" I roll up on before I can get my 3-1/2" jack with the cup removed underneath.
Old Oct 10, 2015 | 07:45 PM
GTJim's Avatar
GTJim
Didn't have one otherwise I would have tried it. I'll get them on tomorrow.
Old Oct 10, 2015 | 07:53 PM
Your luck is like mine - if something can go wrong, it will. Using a piece of wood to roll the tire up onto will give you enough clearance to get the jack under the side of the car. Good luck and post up pics of your ride when you get the new wheels on it.
Old Oct 10, 2015 | 10:28 PM
meflyfrc's Avatar
meflyfrc
I keep RV levelers in my car in case I need to pull a wheel while away from home.
There are perfect to drive up on to get the car high enough to get a jack under the car.
Old Oct 10, 2015 | 10:43 PM
1Willy1's Avatar
1Willy1
i have a low profile jack and it still wont clear, I had to steal some wood from the dumpster and roll up on it before I could remove the wheels
Old Oct 10, 2015 | 11:24 PM
2FAS4UU's Avatar
2FAS4UU
Don't you just Love our cars !!
Old Oct 10, 2015 | 11:47 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
That's why I have the Harbor Freight 3 1/2 ton, 2 7/8".
My old jack didn't cut it either.
Good Luck Jim!!
Old Oct 11, 2015 | 12:16 AM
GTJim's Avatar
GTJim
Yup, if something can go wrong it probably will.
Old Oct 11, 2015 | 07:27 AM
Shakeydeal's Avatar
Shakeydeal
Good luck today with "Wheel Install, Part Deux"........
Shakey
Old Oct 11, 2015 | 08:40 AM
Mickeyrx70's Avatar
Mickeyrx70
I made ramps from 2 x 12's that stair-step to 4" for both front & rear wheels. Only way I can get my low-profile jack under the car. I'm hoping it goes better for you today .... I've been anxious to see pictures of your new wheels mounted too!
Old Oct 11, 2015 | 08:44 AM
Black 02's Avatar
Black 02
I have to drive up on 2x4s even with my low profile Jack.
Old Oct 11, 2015 | 09:13 AM
REDHOTS's Avatar
REDHOTS
That's where a second floor jack is always handy. I just get under the rear crossmember, which is higher, and just lift the rear a couple inches. Then, I can get the second jack, with puck under the rocker. With 2 jacks it is easy to lift either side, or either end.
To Wheel install attempt 1 = FAIL
Old Oct 11, 2015 | 09:14 AM
bjones7131's Avatar
bjones7131
I have to use steped 2x6 beveled on each end for easy on and off but not the rear, jack just clears the rear
Old Oct 11, 2015 | 09:18 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Why not simply jack the car at the crossmember, and you can get either the entire front, or entire rear, off the ground? I roll the car up on either the universal ramps I have, or the short pieces of 2x6, put a piece of wood on the jack's pad, so I don't damage the cradle, and lift away....
Old Oct 11, 2015 | 09:46 AM
REDHOTS's Avatar
REDHOTS
Yes, that works too, but with 2 jacks, it's faster, and no ramps needed, especially for just pulling wheels off, and on.
