Hard to say whether the wire is just dirty or has had some excessive heat. However, have you had the alternator tested to ensure it is providing sufficient output to keep the battery charged? If not, take it to a local parts store - they will usually test it for free and then you can rule out whether the alternator is the culprit.
Yes I have had autozone test it 3 times and it passed their test.
But I read somewhere on LS1tech that even though the alt tested fine does not mean it is still good, the charging circuit could go bad or something like that.
Take a look at the post that red wire attaches to. If the bakelite insulation around that post is charcoaled, you need at least a new solenoid if you can replace it. Most replace the starter and solenoid together. Once that bakelite turns to black powder the post will turn when you try to tighten the nut and won't make good contact. Your voltage will jump up and down from 11 to 14 volts as the car is running, or if really bad, won't ever charge the battery.
I want to test the alternator, what is the proper way to test it.
POS on bolt (rubber boot) ground on chasis, while car is running. Should I be looking for 14Volts?
I guess I have to take off the pass header? Is this complecated to do? To access the starter relay?
I am getting 11.5 volts while driving and going down.
That connection at the starter ties the alternator and battery leads together. Heat from headers makes it more likely that that is your problem. I found it on a friend's Z06 with headers by disconnecting the battery, removing the battery box and turning the nut on the starter solenoid from above, it made a "crackly" sound from the bolt turning in the insulation. He had the same symptoms you have. Replaced the starter, no issues since.
At a minimum you have a problem at the starter solenoid. The insulation on the red positive battery wire is badly overheated and has dried out and cracked. The yellow, black and purple wires are in the same state. You can be sure the Bakelite cap in the end of the solenoid is also burnt and or exposed to excessive heat and is contributing to your issue. I would suggest replacing the solenoid, positive cable and splicing in new yellow, black and purple wires. Make sure all are long enough to tuck away from the headers to prevent a recurrence. As added protection you can wrap the starter with heat insulation. Summit or Jegs has them specifically for starters. Unfortunately this will require the header be disconnected at the collector and head flange so it can drop down far enough to allow access to the starter. Might require complete removal to repair the wiring though. Not good news but needs to happen regardless of weather or not the alternator is good or bad. Good luck and keep us posted.
...Anyway got under car took this photo of starter wire. Is it burned? from heat it does not look normal?...
It's difficult to say for sure by just looking at the picture, but behind the red wire and between the 2 black split looms, there seems to be an "orangy" wire with a blob of what looks like melted insulation. If it is indeed what it looks, then something happened there... You mentioned you have headers, so heat from the headers is a possibility, but remember you also have a couple of fusible links and it could be one of them blew.
On the back of the alternator is a rubber boot covering the bolt to which the large red wire that goes over to the starter is attached. Move back the rubber boot over the bolt. With the engine running measure the voltage from that bolt to a good ground. I personally like the neg battery post but then I have a top post battery in my 04 which makes that much easier than on the side post batteries of the earlier year C5's. Should be 14 or more volts at that point. If significantly less then the alternator is suspect.
If it measures 14 or more volts make note of the actual voltage reading. Then measure the voltage across the battery posts with the engine running. Reading should be very close to what you read at the alternator. If it is significantly less then you need to get at the connections at the bolt on the starter solenoid to find out why.
Thanks I was hopeing you would chim in, will work on it tomorrow and give results. I know the red wire is connected to the starter, I used a small mirror this morning to see it and it is connected. Could I just use the frame of car as ground to use on alternator testing, I dont think my probe is that long to touch neg battery terminal?
I found the problem, its the alternator, while vehicle was idling the same charge on battery 12 volts was same charge as idling 12 volts, then I ran a gound cable from battery to the pos on alternator while vehicle was idling and the value was only 1.
I need a rebuilt.
Re built or Re manufactured?
IMHO...
I TOTALLY agree with getting your OEM RE built... or if you get another DON'T exchange your old one till you know it works... many bad experiences with re manufactured alternators on the C5. Do your research here for the correct part # and where to buy it, IF you go the reman route...
However, if the alternator was working and he connected a cable from the alternator output to the battery negative side I would have expected all hell to break loose with huge sparks and the alternator to probably go up in smoke.
Look at your pic the orange wire that is melted is one of your fusible links. However if you grounded the large post on your Alt. you have more problems.......
OK I tested the alternator positive straight to the battery and guess what 14.2 volts on DIC. So the starter positive was corroted and loose causing the short. I tested the pos starter cable and it was getting the 12 volts to the battery when I took it out. So I bought a new pos terminal cable running from batt to starter. Because the bottom of cable as u can see in the photo above was burned chips falling of the ends. All this morning taking off the header and getting things done.
Sorry about above reply, I was using the multimeter.
Actually corrosion on an electrical connection causes an OPEN or resistance and not a short. A shorted electrical connection is synonymous with sparks or smoke and flames.
Anyway, glad that you found the problem and were able to correct it. Hope you were able to position the wiring to the post on the starter solenoid as far away from the header as possible to avoid a quick reoccurrence of the problem.
I surely hope he can clarify.
Mr. Sam
What's so difficult to understand?
If you run the gound cable from the pos on alt to batt and only 1 value, then the batt charge on battery idling at 12 volts is same as charge idling, then a rebuilt would be needed. Problem solved! Jeez....
Replacing the red wire may get your charge up for a while, but you still need to check the post that it connects to and the insulation around it. If it's burnt, the heat will burn your new cable fairly quickly. That heat built up due to loose or corroded connections and header heat. You'll still have both those with a new red wire.
So what would you recommend thermal tape around the connections?
