Lug nut lock missing
Old Oct 12, 2015 | 07:18 PM
Interapid's Avatar
Interapid
7th Gear
Default Lug nut lock missing
I have a 02 Z06, since Xmas and its time to change tires. There is no lug nut lock in its storage place in the trunk. I looked all over in case it fell down into a well. Whats my options? A friend has the same car but I assume his would be keyed different. Will the dealer make me one for less than $2000? How long? I don't see a code with the paperwork. Ugh
Old Oct 12, 2015 | 07:32 PM
KOZ's Avatar
KOZ
Find a socket that is just smaller than the nut and hammer it on. it should last long enough to spin off the lock. Then discard and continue.
Now you know how to steal 'locked' wheels......
Old Oct 12, 2015 | 07:43 PM
Black 03 Z06's Avatar
Black 03 Z06
That works.
Old Oct 12, 2015 | 07:50 PM
Patches's Avatar
Patches
Before possibly damaging your car/wheel/lugs, why not call a wheel shop and see what they would charge to get it off. I'll bet they deal with this problem all the time. I know the above method works but there's always a chance you damage something unintentionally.
Old Oct 12, 2015 | 08:06 PM
Interapid's Avatar
Interapid
7th Gear
Will the dealer make me one?
Old Oct 12, 2015 | 08:31 PM
Patches's Avatar
Patches
Dealer can order you a new one based on your VIN, IIRC, but you still need to get the locks off. Once those are removed, you can buy any wheel locks you like. I don't run locks becuase thieves know the trick mentioned above so no point. I just leave the car where it's vulnerable if I can help it.
Old Oct 12, 2015 | 10:00 PM
Mickeyrx70's Avatar
Mickeyrx70
I had the same problem & the wheel shop I deal with regularly removed the lock nut for free & without any damage. I didn't see it, but the shop owner said he had a tool made for just such occasions.
Old Oct 12, 2015 | 10:13 PM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
There are tools for this:
http://www.ebay.com/itm/Stripped-Lug-Nut-Remover-Wheel-Lock-Removal-Socket-Tool-/231476062493?hash=item35e50c691d&item=231476062493&vxp=mtr
I've even seen them for sale at Advance Auto. Just make sure you buy the right kind for the lug nuts you have.
Don't half *** it. If you try driving a socket on there, you could split/break the socket and damage your wheel. I'd do it on one of my Demo Derby cars, but not my Corvette.
Old Oct 12, 2015 | 11:28 PM
1Willy1's Avatar
1Willy1
Most shops have wheel lock remover sockets.
Ive been in your position wayyyyyy too many times, it sucks.
Just start calling mechanics, and don't pay more then $10
Old Oct 13, 2015 | 01:30 AM
And sometimes a larger tire store may have some master keys for the locking lugs that may work on yours.
Old Oct 14, 2015 | 07:46 AM
Interapid's Avatar
Interapid
7th Gear
The dealer was no help in getting a key so I just got rid of the locks. I fixed it yesterday by buying 4 new plain lug nuts from the dealer and a removal tool from ORiley for $17. This is a socket set that you just screw onto the offending lock nut and it backs it off. They are especially useful for impact guns but mine worked with a breaker bar. The hardest part was getting the lug nut out of the socket. I ground two flats on the nut, held it in a good vice and tightened the wrench to remove. No more pesky locking lugs.
In 2002 wheel locks came factory. It's in the owners manual, there is a special little storage place for the "key" in the trunk on top of the left frame rail just under the carpet. Mine had no key.
Old Oct 14, 2015 | 08:25 AM
MAC5's Avatar
MAC5
The original lug nut key is most likely at the last tire shop your car visited.
Old Oct 14, 2015 | 09:06 AM
CactusCat's Avatar
CactusCat
Several times I've wondered if one of these would work on those locking lugs?
http://www.sears.com/gator-grips-uni...p-00947078000P
To Lug nut lock missing
