Bleeding brakes question. Does fluid go through the piston when bleeding?
Old Oct 14, 2015 | 10:32 AM
Froggys's Apprentice's Avatar
Default Bleeding brakes question. Does fluid go through the piston when bleeding?
I am trying to get as much old fluid out of my brake system.
If the pads are wore down and the pistons are out quite a bit. When bleeding the brakes does the fluid go through the piston reservoir to the bleeder or is the piston area a dead end for fluid?
If it is a dead end area I was thinking about pushing my pistons in before my next bleed to drive more of the old fluid out.
Thoughts?
Old Oct 14, 2015 | 10:42 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
The position of the piston will make minimal difference. Pushing it back in may help a little, but where the fluid enters the caliper (brake line) and where it exits (bleeder valve) are far enough apart that you will effectively get the old fluid out regardless.
Old Oct 14, 2015 | 11:33 AM
bob guzzy's Avatar
bob guzzy
If you leave the piston out you will be able to flush the whole area behind the piston.
Leave it out then when your done push the piston all the way back with the bleeder open, then re-bleed the system
To Bleeding brakes question. Does fluid go through the piston when bleeding?
